    Anotherone confused by G31 and Homed Height.
    1.2k
    • janjohundefined
      janjoh
      (Delta with Smart effector on Duet Wifi)
      If i run a G30, the printer finds the bed nicely. But, if i after doing that do a G28, and then tell the printer to go to Z0 it comes to hover about 0.7mm above the bed.
      I have searched the forum, but I have not been able to fix this. I do realize i am making some silly error after getting the Smart Effector in place.
      Initially i had "G31 P100 X0 Y0 Z-0.1" But i have also tried Z-0.05, and Z-0.01 but it seem to make no difference.
      So, how do I best use a smart effector to find the true Z-height of the machine?
      [c]config.g
      ; generated by RepRapFirmware Configuration Tool on Sat Mar 10 2018 00:14:59 GMT+0100 (W. Europe Standard Time)
      M665 R179.489 L360.2 B120 H477 X0.746 Y0.761 Z0 ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0.85 Y-0.81 Z-0.04 A0 B0 ; Put your endstop adjustments here, or let auto calibration find them
      M550 PFull Metal Delta ; Set machine name
      M552 S1 ; Enable network
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M92 X200 Y200 Z200 E418.5 ; Set steps per mm
      M566 X1200 Y1200 Z1200 E1200 ; Set maximum instantaneous speed changes (mm/min)
      M203 X18000 Y18000 Z18000 E1200 ; Set maximum speeds (mm/min)
      M201 X1000 Y1000 Z1000 E1000 ; Set accelerations (mm/s^2)
      M906 X1000 Y1000 Z1000 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 Z0 S1 ; Set minimum Z
      M574 X2 Y2 Z2 S1 ; Set active high endstops
      M558 P5 R0.4 F1000 H10 ; Smart Effector
      G31 P100 X0 Y0 Z-0.2
      M557 R125 S20 ; Define mesh grid
      M305 P0 T99670 B4471 C8.262085e-8 R4700 ; Set thermistor + ADC parameters for heater 0
      M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
      M106 P0 S0.3 I0 F10 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M563 P0 D0 H1 ; Define tool 0
      M572 D0 S0.1 ; Pressure advance
      ; Custom settings are configured
      M501[/c]
      [c]config-override.g
      ; Delta parameters
      M665 L360.200 R179.534 H462.487 B120.0 X0.164 Y-0.002 Z0.000
      M666 X0.877 Y-0.903 Z0.026 A0.00 B0.00
      ; Heater model parameters
      M307 H0 A241.5 C325.9 D1.5 S1.00 V12.1 B0
      M307 H1 A263.0 C111.3 D6.3 S1.00 V12.1 B0
      M307 H2 A340.0 C140.0 D5.5 S1.00 V0.0 B0
      M307 H3 A340.0 C140.0 D5.5 S1.00 V0.0 B0
      M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0
      M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0
      M307 H6 A340.0 C140.0 D5.5 S1.00 V0.0 B0
      M307 H7 A340.0 C140.0 D5.5 S1.00 V0.0 B0
      [/c]
      ; homedelta.g
      G91 ; relative positioning
      G1 S1 X555 Y555 Z555 F1800 ; move all towers to the high end stopping at the endstops (first pass)
      G1 X-5 Y-5 Z-5 F1800 S2 ; go down a few mm
      G1 S1 X10 Y10 Z10 F360 ; move all towers up once more (second pass)
      G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred
      G90 ; absolute positioning
      G1 X0 Y0 F6000 ; move X+Y to the centre
        G28 resets the Z=0 position based on the trigger positions of the homing switches and the M665 and M666 parameters. Since the homing switch trigger positions may vary, and thermal expansion may change the homed height slightly, between homing and starting to print it's best to run either auto calibration or at least do a single G30 probe. Doing 3-point or greater auto calibration is best, because that takes out any variation in the homing switch trigger positions.
        If the 0.7mm offset is consistent, that sounds like your M665 H parameter isn't quite right. Are your M665 parameters ones you obtained by auto calibration? Did you auto calibrate with the printer at or close to printing temperature?
        • DjDemonDundefined
          DjDemonD
          It would seem to me that after doing a G30 which is effectively homing Z, I would not be doing a G28 and moving the three carriages back to the endstops quite far away, I'd be getting on with printing something. Perhaps your endstops are not very repeatable, or your steps/mm is just a tiny fraction off, for example, 0.7mm error over 400mm of movement (height of my delta) is only 0.175% error in steps/mm!
          I do G28, then auto-calibrate, then print. I home at the end of a print and find I can skip autocalibration next time, but I have optical endstops, and my steps/mm is I believe spot on. But I wouldn't trust it to hold its calibration for a long period of time. This is the beauty of smarteffector or piezo probe, the convenience and accuracy to do autocalibration routinely.
          I have a smart effector on one machine. If you set your G31 offset to z0 and do G30 (use the latest firmware with multitouch and set fairly tough tolerance of 0.01, so you get a very accurate probing result) then go up to z10 and back down to Z0. Can you get a piece of paper in there between the nozzle and bed? Try it, then you can determine the actual z offset which is usually -0.1. Or print an object and babystep to the perfect layer height, usually by going up 0.1 - i.e. z offset -0.1. Then you have your z offset verified.
          www.precisionpiezo.co.uk
          • janjohundefined
            janjoh
            Ah.. Ooh… I thought that a G30 with probe automatically reset the Height.
            Well, it seem that i have found where my problem is. And I will heed the advice to include a quick calibration mor often.
              @janjoh:
              It does reset the height… until you home again. Whereas auto calibration resets the M665 parameters too, therefore it affects the height even after homing again.
              • janjohundefined
                janjoh
                @dc42:
                @janjoh:
                Ooooooohhhhh, that explains all.
                I am converting from smoothieware, which needs a G28 before new calibration parameters are used.
                Edit: Just re-ran in that sequence, and now all is spot on. As for my end stops, i did a series of calibrations, and got around 0.02mm deviation. So, i think that is good enough for now.
                Thank you!
                • SputnikOC3dundefined
                  SputnikOC3d
                  So … I too have been fighting with first kayer height issues that have been driving me batty ... but if I understand this thread correctly ... If Ive homed all right after power up - so I can run a fresh new Mesh Bed Level routing to save to the SD card ... if Im doing a G28 in my start GCode then Im resetting the Z height all over again and essentialy negating the seemingly endless mesh bed leveling probe?
                  BUT ... not sure that is right because .... If I must home all [ Cartesian \ Prusa style ] in order to get to the Run Mesh Bed Leveling probe routine … Ive reset z again ?
                  Im not sure what the issue is with my setup - but Im having to baby sit the first layer on every print ... and adjusting the first layer height + and - from .10 thru .25 - last night I had to raise Z by baby steps by .25+ to get decent 1st layers ... and its different every day I print....
                    If you are homing Z using the Z probe, then if you home again after running mesh bed compensation, homing shouldn't affect the Z height, assuming the Z probe triggers at a consistent height. The difficulty comes when you use an endstop switch for Z homing, because the endstop switch and the Z probe probably have slightly different ideas about where Z=0 is.
                    If you home using a switch and use G29 S1 to load a pre-generated height map, then it's a good idea to do a single G30 Z probe at bed centre after homing, to re-establish where Z=0 is using the probe.
                      SputnikOC3d
                      OK TY …
                      Then now Im even more baffled as to what my actual issue could be...
