    BLTouch working
    266
    79.5k
    • Motalwundefined
      Motalw
      @claustro:
      @dc42:
      Have you read https://duet3d.com/wiki/Using_mesh_bed_compensation ?
      I have another problem , when I home the Z probe seems to work perfectly, the printer register the touch point and the home Z button become blue . The problem is the probe that after touching the bed with the pin it start flashing and I have to reset it manually https://www.youtube.com/watch?v=eq2wTy3-kxA
      this is my homing routine
      [c]G91 ; relative mode
      G1 Z4 F200 ; raise head 4mm to ensure it is above the Z probe trigger height
      G90 ; back to absolute mode
      M98 Pdeployprobe.g
      G1 X150 Y150 F2000 ; put head over the centre of the bed, or wherever you want to probe
      G30 ; lower head, stop when probe triggered and set Z to trigger height[/c]
      Hope you'll be able to understand my very mad English 🙂
      I have the same problem when the pin drops after homing Z but it doesn't always happen. did anyone have this problem? and how did you fix it?
      Also, my homing only works with M558 P1 instead of P5. any idea why?
      all connections are correct as far as I know.
      • Nylkosundefined
        Nylkos
        No idea, but you seem to be in the same boat has I…
        What I had to do:
        Like in https://duet3d.com/wiki/Connecting_a_Z_probe
        but use P1 instead of P5 and change your P value in G31 (I used P200)
        M307 H3 A-1 C-1 D-1 ;
        M558 P1 X0 Y0 Z1 H5 F100 T2000
        G31 X0 Y0 Z0 P200
        use deployprobe.g (M280 P3 S10 I1)& retractprobe.g (M280 P3 S90 I1)
        Thread
        Source:https://www.duet3d.com/forum/thread.php?id=2539&p=2
        Can you post your homez.g file?
        I do not have access to my file from work but I might be able to help.
        • Motalwundefined
          Motalw
          I'm at work right now but I believe my Homez is:
          ; homez.g
          ; Lift Z relatively to current position
          G91
          G1 Z5 F6000
          ; Back to absolute positioning
          G90
          ; Go to first bed probe point and home the Z axis
          G1 X15 Y15 F6000
          G30
          ;G91
          ;G1 Z5 F100
          ;G90
          one thing came to my mind now… maybe I have used the 10k resistor instead of the 240 ohm. need to double check it when I get home.
          would it be a possible explanation?
          • Nylkosundefined
            Nylkos
            @Motalw:
            ; homez.g
            G91
            G1 Z5 F6000
            G90
            G1 X15 Y15 F6000
            G30
            ;G91
            ;G1 Z5 F100
            ;G90
            did you create deployprobe.g (M280 P3 S10 I1) & retractprobe.g (M280 P3 S90 I1)?
            If no, you need to create those files with the command ()
            Once you have them, add the Pdeployprobe.g & Pretractprobe.g command in your homez.g file:
            M98 Pdeployprobe.g
            G1 X15 Y15 F6000
            G30
            M98 Pretractprobe.g
            To test, click manually home X, Home Y, Home Z, do not click home all.
            Let me know how it goes
            • Nylkosundefined
              Nylkos
              I forgot to mention:
              You can try to use the M401 & M402 command instead of the deployprobe.g & retractprobe.g,
              I have to use deployprobe.g & retractprobe.g, but I was having issues with the BLTouch.
              For me, the M401 & M402 command were working with the M558 P5, but not with the M558 P1
              • Nylkosundefined
                Nylkos
                I am suggest that you create a resetalarm.g (your call on the name) file with M280 P3 S160 I1.
                That way, you can cancel the alarm by using
                M98 Presetalarm.g
                instead of remembering the M280 P3 S160 I1 command or resetting your printer.
                • Motalwundefined
                  Motalw
                  @Nylkos:
                  I had the same problem it would not deploy or retract using M401 & M402.
                  I have to check that resistor… Also need to check if I have any config override file. because all the rest is right I believe.
                  • Motalwundefined
                    Motalw
                    @Nylkos:
                    M98 Presetalarm.g
                    I have add it to my Default G-Codes (drop down menu).
                    • Nylkosundefined
                      Nylkos
                      Were you able to test your homez.g?
                      • Motalwundefined
                        Motalw
                        @Nylkos:
                        Not yet, I'm working till late tonight. I'll post a feed back Around 9pm.
                        and yes I do have the files retract & deploy. I did add it to bed.g & homeall.g but forgot about homez.g.
                        But if I'm not wrong I believe it deploy and retract the probe automatically when i use G30.
                        • Motalwundefined
                          Motalw
                          @Nylkos:
                          I have tested it but it work just as my configuration without theM98 commands.
                          I also I'm using the correct resistor.
                          ever thing works "almost" fine if I use M558 P1 but the probe drops some time.
                          this is my configuration maybe I missed some thing;
                          ; Configuration file for Duet WiFi (firmware version 1.17)
                          ; generated by RepRapFirmware Configuration Tool on Tue Sep 19 2017 08:19:05 GMT+0100 (GMT Daylight Time)
                          M111 S0 ; Debugging off
                          G21 ; Work in millimetres
                          M667 S1 ; Select CoreXY mode
                          M208 X430 Y330 Z450 S0 ; Set axis maxima
                          M574 X1 Y1 Z0 S0 ; Define active low and unused microswitches
                          M558 P1 X0 Y0 Z1 H5 F120 T9000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
                          G31 P10 X0 Y40 Z2 ; Set Z probe trigger value, offset and trigger height
                          M557 X15:415 Y15:315 S20 ; Define mesh grid
                          M569 P4 S1 ; Drive 4 goes forwards
                          M569 P5 S1 ; Drive 5 goes forwards
                          M350 X16 Y16 Z16 E16:16:16 I1 ; Configure microstepping with interpolation
                          M92 X100 Y100 Z400 E383:383:383 ; Set steps per mm
                          M566 X1200 Y1200 Z12 E240:240:240 ; Set maximum instantaneous speed changes (mm/min)
                          M203 X6000 Y6000 Z180 E3000:3000:3000 ; Set maximum speeds (mm/min)
                          M201 X500 Y20 Z250 E250:250:250 ; Set accelerations (mm/s^2)
                          M906 X1200 Y1200 Z1500 E800:800:800 I30 ; Set motor currents (mA) and motor idle factor in per cent
                          M84 S30 ; Set idle timeout
                          M143 S275 ; Set maximum heater temperature to 275C
                          M563 P0 D0 H1 ; Define tool 0
                          M563 P1 D1 H1 ; Define tool 1
                          G10 P1 X0 Y0 Z0 ; Set tool 1 axis offsets
                          G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
                          M563 P2 D2 H1 ; Define tool 2
                          G10 P2 X0 Y0 Z0 ; Set tool 2 axis offsets
                          G10 P2 R0 S0 ; Set initial tool 2 active and standby temperatures to 0C
                          M550 PUltima Bot ; Set machine name
                          M552 S1 ; Enable network
                          ; Access point is configured manually via M587 by the user
                          M586 P0 S1 ; Enable HTTP
                          M586 P1 S0 ; Disable FTP
                          M586 P2 S0 ; Disable Telnet
                          M106 P1 S1 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
                          M106 P2 S1 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
                          ; Custom settings
                          M307 H7 A-1 C-1 D-1 ;disable heater 7 on pmw5
                          T0 ; Select first tool
                          Bed.g
                          ; bed.g
                          ; generated by RepRapFirmware Configuration Tool on Mon Sep 18 2017 19:18:06 GMT+0100 (GMT Daylight Time)
                          ; Clear any bed transform
                          M561
                          ; Deploy the mechanical Z probe
                          M98 Pdeployprobe.g
                          ; Probe the bed at 5 points
                          G30 P0 X15 Y15 H0 Z-99999
                          G30 P1 X15 Y315 H0 Z-99999
                          G30 P2 X415 Y315 H0 Z-99999
                          G30 P3 X415 Y15 H0 Z-99999
                          G30 P4 X215 Y165 H0 Z-99999 S
                          ; Retract the mechanical Z probe
                          M98 Pretractprobe.g
                          Homeall.g
                          ; homeall.g
                          ; called to home all axes
                          ; generated by RepRapFirmware Configuration Tool on Mon Sep 18 2017 19:21:01 GMT+0100 (GMT Daylight Time)
                          ; Relative positioning
                          G91
                          ; Lift Z
                          G1 Z5 F9000
                          M98 Pdeployprobe.g
                          ; Course home X and Y
                          G1 X-435 Y-335 F3600 S1
                          ; Move away from the endstops
                          G1 X5 Y5 F9000
                          ; Fine home X and Y
                          G1 X-435 Y-335 F360 S1
                          ; Absolute positioning
                          G90
                          ; Go to first bed probe point and home Z
                          G1 X15 Y15 F9000
                          G30
                          ; Uncomment the following line to lift the nozzle after probing
                          ;G1 Z10 F150
                          M98 Pretractprobe.g
                          Homez.g
                          ; homez.g
                          ; called to home the Z axis
                          ; generated by RepRapFirmware Configuration Tool on Tue Sep 19 2017 08:11:32 GMT+0100 (GMT Daylight Time)
                          G91
                          G1 Z5 F9000
                          G90
                          G1 X15 Y5 F9000
                          G30
                          G91
                          G1 Z5 F150
                          G90
                          • Nylkosundefined
                            Nylkos
                            What are your values in Z-Probe for triggered and deploy?
                            • Motalwundefined
                              Motalw
                              The shows 4 some times 5 when triggered and 0 when not triggered. (using M558 P1)
                              If I uses M558 P5 then it will always be 0.
                              • Motalwundefined
                                Motalw
                                just run a mesh grid and this was the results :
                                share pics online
                                I'm Almost giving up on this … I have tried the DC42 IR Probe but because my heatbed is glass when I use tape or ABS juice on the surface the IR probe needs to be re-calibrated.
                                • Nylkosundefined
                                  Nylkos
                                  I just noticed that in your HomeZ.g you do not deploy or retract.
                                  • Motalwundefined
                                    Motalw
                                    @Nylkos:
                                    it is not necessary because the firmware does it automatically when G30 is called. but I have tried it with the deploy and retract code but did not make any difference.
                                    I have now just tried to do a mesh levelling using the DC42 IR Probe and this was the result;
                                    I have a aluminium heat bed painted black and with a 6mm sheet of glass on top of it so it is 100% flat. I dont know why I keep get this results with the BLTouch and the IR Probe. any idea?
                                    • Motalwundefined
                                      Motalw
                                      just did a mesh grid using the BLTouch and another with the DC42 IR Probe. can anyone help with it?why both of then are giving bad results?
                                      BLTouch
                                      DC42 IR Probe
                                      • Nylkosundefined
                                        Nylkos
                                        How is your bed mounted, is the movement smooth or staggered at low and fast speed
                                          The IR probe results have one corner point much lower than the rest. There must be something in that corner to cause that, or perhaps you are probing too close to the edge.
                                          • Motalwundefined
                                            Motalw
                                            It is a Modified D-Bot with 3 x T8 rods its pretty solid. and the heat bed is a 6mm sheet of glass over a aluminium plate painted black.
                                            it is probing at least 50mm away from the edges.
                                            I am doing some tests now with the DC42 IR Probe it seems to be more reliable than the BLTouch.
                                            got this result doing a probing in just 1 point with this setting
                                            M558 P1 X0 Y0 Z1 H5 F120 T12000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
                                            G31 P200 X0 Y0 Z1.4 ; Set Z probe trigger value, offset and trigger height
                                            M98 P0:/macros/BLTouch 20 probing 1 point
                                            Bed probe heights: -0.657 -0.660 -0.660 -0.655 -0.657 -0.657 -0.655 -0.660 -0.657 -0.657 -0.662 -0.662 -0.655 -0.657 -0.660 -0.655 -0.652 -0.662 -0.657 -0.657 -0.660, mean -0.658, deviation from mean 0.003
                                            Now I will do a G29 and see if it is consistent with this result.
