    New firmware 1.21RC5 available
    Firmware installation
    15
    57
    5563
      RepRapFirmware doesn't expect drives to need an enable setup time. So it's likely that the first few steps after the drive is first enabled will be missed. This won't normally matter because they will be homing steps.
      I suggest you install the 1.21 final release (which includes the change to modify the step pulse timing) and re-run your test; but this time, command the motor to move a little (so that the firmware enables the driver; and only then mark the position so that you can compare it at the end. Also make sure that you don't have a M84 or similar command in your end GCode, because that will disable the drivers.
      • Shen
        Shen last edited by
        @dc42:
        I've just re-ran the test with the 1.21 final release, and the problem persists. My driver is enabled before I mark the position on both this test and my previous tests, there is no homing or M84 or any other command that would affect the shaft position in the gcode. I'm actually not only comparing the marks at the end, but also during the test, I pause the print, issue G1 X100(where i draw the mark), and compare the marks, they don't match up, it also drifts slightly between pauses.
        • DougJones
          DougJones last edited by
          I've tested with the special "even" firmware you suggested. I put the closed-loop stepper back on the x-axis.
          Running the 3DBenchy again, I get the same results (still getting the layer shifting). I am using the following settings for signal generation:
          M569 P6 S1 R1 T10:10:7:2
          I am printing at 40mm/sec with 80 pulses per mm, so that's about 3200 pulses pulses/second or 3.2kHz (that's a GT2 belt with 20 teeth - one rev per 40 mm - drive is set to 3200 p/rev). That's not fast at all. So, unless I am missing something. I don't think I'm anywhere near the 25kHz. For information, the drives say they are good to a max of 200kHz.
          The same 80 pulses/mm correspondes to 16x microstepping and when I use the builtin stepper driver with these speeds/settings the parts produced look pretty good with no layer shifting.
          • DougJones
            FYI, my external drives are always enabled. I do not use the enable signals. So I don't think that I am seeing an issue related to enable signal timing.
              It sounds to me that your closed loop drives are missing steps under some situations. Do they have an alarm output that you can monitor, to see if they know that they have missed steps?
              • Shen
                Shen last edited by
                I have my alarm connected to a end stop and set a trigger to emergency stop. It never triggers during a print. To me it doesn't look like missing steps, my steppers are over powered for my print, and the pattern of shifting seems consistent and gradual, it's not shifting by a entire step each time, rather it's shifting by steps.
                • DougJones
                  The alarm signal never triggers
