    Resurrect.g is 0kb
    • pabomanundefined
      paboman
      If I unplug the printer from the main power a resurrect.g file is created but its 0Kb
      I am running a meanwell 24v Power supply
        Which firmware version are you running; and what M911 command do you have in config.g?
        • pabomanundefined
          paboman
          Firmware Version: 1.21RC5 (2018-03-16 build 1)
          WiFi Server Version: 1.21RC4(08b3)
          Web Interface Version: 1.21-RC4
          ; Automatic power saving
          M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
            Your S and R values are much too low. I use S20 R22. Even better would be S22 R23 if your PSU output voltage never normally dips below 22V.
            • pabomanundefined
              paboman
              Ok I will try thank you
              what is the R value ?
              • pabomanundefined
                paboman
                now it works! thanks again
