    Static IP [solved]
    • DjDemonD
      DjDemonD last edited by
      Hi, would anyone care to share the part of their config.g (for a duet wifi) which enables static IP (I'm running 1.21 rc5 but I presume any 1.21 rcx version will work the same).
      I have up until now been running 3 machines with DHCP, and have setup router reservations for them, but wanted to neaten things up.
      Thanks in advance.
      www.precisionpiezo.co.uk
      • DjDemonD
        Okay so I solved my own problem. In case it helps here's how I did it.
        I made a file using my pc on the SD card in macros called setnetwork:
        M552 S0					;stop wifi
        G4 P1000				;pause
        M587 S"3DP" P"********" I192.168.0.4 J192.168.0.1 K255.255.255.0		;add my network and IP address,gateway,netmask
        Then changed my config.g networking section to just
        ;networking
        M540 P**************************; MAC Address
        M552 S1 				;start wifi
        -Reinserted the sd card into the duetwifi and hit the reset button
        -Connect the machine by USB and opened console in pronterface.
        -Sent M558 S"*" which forgets all known networks, send it like that the * means all networks
        -Then M98 P/macros/setnetwork
        Then restarted the machine now its IP address is 192.168.0.4 as I wanted it to be.
        (obviously the data in the fields above refers to my network and machine, I have replaced anything sensitive with ***** - I know this is obvious to most, but just in case)
        • PlasticMetal
          PlasticMetal last edited by
          This is an Ethernet model, but I would think they would be essentially the same.
          ; Communication and general
          M111 S0
          M550 PRostock MAX V2
          M551 Pxxxxxxxxxx
          ;*** If you have more than one Duet on your network, they must all have different MAC addresses, so change the last digits
          M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED 	; MAC Address
          M552 S1					; Turn network on
          ;*** Ethernet networking: Adjust the IP address and gateway in the following 2 lines to suit your network
          M552 P192.168.1.119			; (0 = DHCP)
          M554 P192.168.1.1			; Gateway
          M553 P255.255.255.0			; Netmask
          • DjDemonD
            Thanks, so there are several methods.
              The Duet Ethernet and the older Ethernet Duets use M552/554/553 to set the IP address, gateway and netmask because you only need one set. On the Duet WiFi, you may need a different set depending on which WiFi network you connect to. That's why the parameters are included in the M587 command for the Duet WiFi.
              • gavatron3000
                gavatron3000 last edited by
                Another way is to set the Mac address in the router to have a specific address. I had to do this due to not being able to access the internet through my pi for updates. And it's easy as to do.
