    Fully enclosed with custom UI
    My Duet controlled machine
    12
    28
    6.2k
    • Danalundefined
      Danal @AdiGital
      @adigital said in Fully enclosed with custom UI:
      Yes, the walls were covered with vinyl. I thought it was the easiest solution giving acceptable results. However, it wasn't as easy as I thought to lay it without wrinkles.
      I've had great success putting vinyl on aluminum by spraying plenty of water on both the aluminum and the sticky side of the vinyl. Very SMALL amount of dish soap in the water, just enough to break the surface tension. And then squeegee, squeegee, squeegee!!
      Works great.
      In fact, this instrument panel is "shelf paper" vinyl over aluminum, applied before it was CNC cut.
      • tjb1undefined
        tjb1 @fma
        @fma said in Fully enclosed with custom UI:
        Any news about mini-display files and code? I would love to build one...
        Also very interested in the small display!
        • AdiGitalundefined
          AdiGital
          Apologies I was inactive for so long. Was busy with something else. I didn't even update the Duet firmware and I'm still on 1.xx.
          After planning on publishing more detailed video/review of the printer I failed to do so. I eventually gave up and today published a "work in progress" version I created some time ago. Just came here to post a link and found the posts. Really sorry.
          I'll do my best to dig up all I've got for the UI display and create the documentation. It's quite simple design.
          The video if anyone interested:
          https://youtu.be/y1CbmgtJGtQ
          My fully enclosed design
          DennisHallundefined 1 Reply Last reply Reply Quote 0
          • A Former User?
            A Former User
            Looks like the cooling for the Duet moves the majority of the air on the top of the board, I think recall reading cooling should be on the bottom of the board for the stepper drivers at least? But if you're not running high currents then it probably wont matter.
            • DennisHallundefined
              DennisHall @AdiGital
              @adigital Your Printer is nothing short of "STUNNING"!
              Your video is also actually really well done!
              • AdiGitalundefined
                AdiGital
                And here is the SUIFD code and short connections description:
                https://github.com/AdiGitalEU/SUIFD
                @bearer - the cooling is on the back side as well. The board is pressed against aluminium bar via thermo pad.
                Thank yuo @DennisHall 🙂
                • A Former User?
                  A Former User
                  Nice! Love the attention to detail!
                  Slightly off topic, this wife of yours - any chance she has a sister? 😇
                  AdiGitalundefined 1 Reply Last reply Reply Quote 1
                  • AdiGitalundefined
                    AdiGital @A Former User
                    @bearer Haha! She liked your comment 🙂 I printed her a couple of kitchen tools and she was all happy 😉
