    Fully enclosed with custom UI
    My Duet controlled machine
    12
    28
    6.2k
    • ShadowXundefined
      ShadowX
      I can't tell from pic, but the SSR and power supply should also have a shield over any exposed wiring if its connected to AC. This is more to prevent electrocution.
      • AdiGitalundefined
        AdiGital
        @BikingViking:
        […] brain fart > zzzt
        haha πŸ˜„
        @ShadowX - sure, good points. The whole bottom part is covered and under normal use eventual spills/drops won't reach electronics. Frame is grounded and the "water path" is kept outside. More photos will follow.
        My fully enclosed design
          T3P3Tony administrators
          aha! so you are connecting the ESP to the PanelDue header?
          • AdiGitalundefined
            AdiGital
            @T3P3Tony:
            Yes, that's correct.
            I'm using a few libraries to get the JSON data, handle the screen, UI jpg files and so on, and just sending the G-code commands back to it. So it really is micro-PanelDue (read: a poor substitute). The were two reasons I made it: I wanted to give the printer my personal touch, and I didn't have much space for the original PanelDue.
            • Cataundefined
              Cata
              Nice lcd setup. I need one of that
              • fmaundefined
                fma
                Any news about mini-display files and code? I would love to build one...
                FrΓ©dΓ©ric
                tjb1undefined 1 Reply Last reply Reply Quote 0
                • Danalundefined
                  Danal @AdiGital
                  @adigital said in Fully enclosed with custom UI:
                  Yes, the walls were covered with vinyl. I thought it was the easiest solution giving acceptable results. However, it wasn't as easy as I thought to lay it without wrinkles.
                  I've had great success putting vinyl on aluminum by spraying plenty of water on both the aluminum and the sticky side of the vinyl. Very SMALL amount of dish soap in the water, just enough to break the surface tension. And then squeegee, squeegee, squeegee!!
                  Works great.
                  In fact, this instrument panel is "shelf paper" vinyl over aluminum, applied before it was CNC cut.
                  • tjb1undefined
                    tjb1 @fma
                    @fma said in Fully enclosed with custom UI:
                    Also very interested in the small display!
                    • AdiGitalundefined
                      AdiGital
                      Apologies I was inactive for so long. Was busy with something else. I didn't even update the Duet firmware and I'm still on 1.xx.
                      After planning on publishing more detailed video/review of the printer I failed to do so. I eventually gave up and today published a "work in progress" version I created some time ago. Just came here to post a link and found the posts. Really sorry.
                      I'll do my best to dig up all I've got for the UI display and create the documentation. It's quite simple design.
                      The video if anyone interested:
                      https://youtu.be/y1CbmgtJGtQ
                      DennisHallundefined 1 Reply Last reply Reply Quote 0
                        A Former User
                        Looks like the cooling for the Duet moves the majority of the air on the top of the board, I think recall reading cooling should be on the bottom of the board for the stepper drivers at least? But if you're not running high currents then it probably wont matter.
                        • DennisHallundefined
                          DennisHall @AdiGital
                          @adigital Your Printer is nothing short of "STUNNING"!
                          Your video is also actually really well done!
                          • AdiGitalundefined
                            AdiGital
                            And here is the SUIFD code and short connections description:
                            https://github.com/AdiGitalEU/SUIFD
                            @bearer - the cooling is on the back side as well. The board is pressed against aluminium bar via thermo pad.
                            Thank yuo @DennisHall πŸ™‚
                              A Former User
                              Nice! Love the attention to detail!
                              Slightly off topic, this wife of yours - any chance she has a sister? πŸ˜‡
                              AdiGitalundefined 1 Reply Last reply Reply Quote 1
                              • AdiGitalundefined
                                AdiGital @A Former User
                                @bearer Haha! She liked your comment πŸ™‚ I printed her a couple of kitchen tools and she was all happy πŸ˜‰
