    After 19 hours of printing: Printing paused:heater fault
    3127
    • FBG
      FBG last edited by
      I start my first print, everything is absolutely perfect, is incredible the quality of the prints now….
      But, after 19 hours the display show this:
      The machine is paused, how i can continue without lose the print part?
      What i can check? What happen? What heater is broken? I can see some log?
      Duet Wifi Version 1.21 RC5
      • FBG
        FBG last edited by
        In Gcode Console i found 4 messages likes this:
        What mean?
          You can clear the heater fault using M562 (see https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M562_Reset_temperature_fault)) then press Resume. But see the wiki page on spurious heater faults after your print finishes.
          That message suggests a corrupted gcode file.
          • FBG
            FBG last edited by
            Corrupted gcode file? I do with simplify3d like always before.
            Can i see something in this?
            But you check than show: Error: temperature reading fault on heater 1.
            I use Thermocouple K, is possible than do a problem and if show 2000ºC happen this fault or not?
            • FBG
              FBG last edited by
              I do M562 but the error happen again!, is continuously
                If it's happening continuously and it was working before, then something has changed e.g.:
                • Thermocouple has become disconnected from the daughter board
                • Thermocouple is shorting to the heater block
                • Thermocouple broken (gone open circuit)
                • FBG
                  FBG last edited by
                  Finally i restart the machine….
                  and now happen this:
                  I Preheat and the temperature go up 4-5 seconds but show this....
                  Error: Heating fault on heater 1, temperature rising much more slowly than the expected 1.7°C/sec
                    Have run M303 tuning on that heater/thermocouple/hot end combination since you last changed anything?
                    • FBG
                      FBG last edited by
                      Not. I do the first time and the config is saved in config-override and i don't touch anymore
                      i am doing in this moment a new M303, by the way i add in Config M570 H1 P60 T15.
                      A question, is possible restart for the point where the machine was paused?
                      I have this info in the file resurrect.g:
                      [[language]]
                      ; File "r2d2_-_leg_left.gcode" resume print after print paused at 2018-03-21 14:53
                      M140 P0 S50.0
                      G10 P1 S245 R245
                      T1 P0
                      G10 P0 S225 R225
                      T0 P0
                      M98 Presurrect-prologue.g
                      M106 P0 S1.00
                      M106 P3 S0.00
                      M106 P4 S0.00
                      M106 P5 S0.00
                      M106 P6 S0.00
                      M106 P7 S0.00
                      M106 P8 S0.00
                      M106 S255.00
                      M116
                      M290 S0.000
                      G92 E0.00000
                      M83
                      M23 r2d2_-_leg_left.gcode
                      M26 S6360220 P0.000
                      G0 F6000 Z28.000
                      G0 F6000 X637.04 Y347.85
                      G0 F6000 Z26.000
                      G1 F3030.0 P0
                      M24
                        You may be able to resume the print when you have fixed the heater issue, but you will need to set up your resurrect-prologue.g file first. See https://duet3d.dozuki.com/Wiki/Setting_up_to_resume_a_print_after_a_power_failure.
                        • FBG
                          FBG last edited by
                          I do M303 H1 S225 P0.5
                          M307 H1
                          Heater 1 model: gain 336.2, time constant 308.0, dead time 6.2, max PWM 0.50, calibration voltage 24.0, mode PID, inverted no, frequency default
                          Computed PID parameters for setpoint change: P26.3, I0.600, D114.5
                          Computed PID parameters for load change: P2
                          OLD value: M307 H1 A393.5 C296.9 D6.1 S0.60 V24.0 B0
                          New value: M307 H1 A336.2 C308.0 D6.2 S0.50 V24.0 B0
                          Something rare? I have 40W 24V e3dv6
                            The gain has gone down from 393 to 336, which is nearly 20%. That implies either that your heater has lost power, or that cooling of the hot end has increased. Check that the screws in the extruder heater terminal block on the Duet are still tight.
                            • FBG
                              FBG last edited by
                              I see a thing….
                              the old value is with: M303 H1 S225 P0.6
                              the new value is with: M303 H1 S225 P0.5
                              is important this, or is indifferent?
                                Why are you using a PWM factor other than 1 when running M303? It's been standard to use full PWM when running M303 for several firmware versions.
                                • FBG
                                  FBG last edited by
                                  This is incredible, now i do: M303 H1 S225 P0.5 and say:
                                  Auto tune cancelled because target temperature was not reached
                                  If i do: M303 H1 S225 say:
                                  Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 735C.
                                  Auto tune heater 1 completed in 436 sec
                                  Use M307 H1 to see the result, or M500 to save the result in config-override.g
                                  Now the value in config-override is: M307 H1 A710.6 C318.6 D9.7 S1.00 V23.9 B0
                                    Like many users, you have an over-powered hot end heater. You can still print with those values. For safety reasons you may wish to order a lower power heater cartridge.
                                    • FBG
                                      FBG last edited by
                                      I start the print again from the beginning, and after 20 hours now i can see than the temperature NOT is estable, why??
                                      The first 20hours (aprox) is absolutely stable +/-1º and now with 30 hours:….
                                      Now go from 216ºC to 233ºC
                                      Of course same temperature is config in all print in 225º and only use T0
                                      I don't have configured line M570 so i am frightened for the print, maybe go to give some error if the temperature continue fail?
                                      Not errors show in console. I don't have fans or something than can cool the nozzle, chamber closed and same temperature in bed always
                                        Undulating temperature usually means that the dead time parameter (D in M307) is too low. It could mean that the thermal contact between your heater cartridge and the heater block isn't as good as it used to be.
                                        • FBG
                                          FBG last edited by
                                          This extruder is used several months with arduino and marlin firmware without problems, i check the wires and thermal contact and absolutely ok.
                                          The question is, Why after 20 hours start to fail?
                                          I am thinking in use the M301 with PID parameters than i was use in the marlin firmware, instead of M303 system.
                                          I don't finish to work perfectly with this M303 auto tuning
                                            If it used to work but doesn't any more, then something must have changed. Your dead time parameter does look unusually high, suggesting that heat transfer from the heater cartridge to the heater block isn't as good as it should be. Values around 6 seconds are more usual for E3DV6 and similar hot ends. What type of hot end is it?
                                            You could try running M303 tuning again and see if the dead time parameter has changed.
                                            • FBG
                                              FBG last edited by
                                              This:
                                              https://e3d-online.com/v6-plated-copper-heater-block
                                                Copper has a thermal capacity per unit volume about 50% higher than aluminium, so that explains the 50% higher dead time.
                                                I suggest you increase the D parameter in the M307 H1 command enough to make the undulations go away. Try increasing it by 20%.
                                                • c310
                                                  c310 last edited by
                                                  I faced similar issue: searched forum, but none of the proposed solution helps.
                                                  as a sudden it gives heater fault. im on 1.21…
                                                  1-a) i replaced heater cartridge and checked all connections, including PT-100.
                                                  all looks fine. Run M303 H1 P1 S230 . No issues… M500 ..
                                                  1-b) after restart and even after power off problems does not disappear.. 😞
                                                  printer does resume with m562 + m916 but minutes later all repeats again…
                                                  2-a) increased tolerance M570 S120 H1 P10 to avoid some peaks.
                                                  2-b) after M562+M916 it starts printing, but in less than a second temperature starts dropping very slowly.
                                                  chart is clean (no spikes, holes etc)
                                                  1. i thought it is a large file… tried to print 101010 cube. same at around 50% completion ....
                                                    replaced SD card, no luck. i think i have tried everything but PT-100 sensor that i do not have in stock...
                                                  what can i do to fix the issue???
                                                  [c]21:30:42 Error: Heating fault on heater 1, temperature rising much more slowly than the expected 0.3°C/sec
                                                  21:30:32 T-1
                                                  21:30:30 M562
                                                  21:29:48 Printing paused
                                                  21:29:46 Error: Heating fault on heater 1, temperature excursion exceeded 15.0°C
                                                  Resume-after-power-fail state saved
                                                  [/c]
                                                  M307 H0 A90.0 C700.0 D10.0 S1.00 V0.0 B1
                                                  M307 H1 A272.9 C189.4 D2.2 S1.00 V12.0 B0
                                                  M307 H2 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                                                  M307 H3 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                                                  M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                                                  M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                                                  M307 H6 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                                                  M307 H7 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                                                    The "temperature rising more slowly than expected" error normally means the heater has not been tuned. You saved the results to config-override.g with M500, but does config.g have a M501 command at the end to run config.g?
                                                    The "temperature excursion exceeded" error is explained on the wiki page. The error message you pasted says the limit is 15C (the default), which is not what your M570 command indicates.
                                                    • c310
                                                      c310 last edited by c310
                                                      David, can it be something with my board or firmware (fault detection algorithm) ??
                                                      i replaced heat cartridge again... and system was printing fine for a day or two. yesterday as a sudden heater fault again.
                                                      i pulled it from outlet and decided to try next morning... results are very strange... very.
                                                      my steps:
                                                      1. i switched system on and
                                                      2. almost immediately connected via web interface.
                                                      3. almost immediately i faced "temperature excursion exceeded 15.0C"
                                                      in wiki this error residing in "maintaining temperature" section. but in my case it was only heating up for few seconds.
                                                      config.g related
                                                      M563 P0 D0 H1 F0
                                                      G10 P0 S200 R180
                                                      M570 S120 H1 P10 T15
                                                      M305 P1 X200
                                                      @dc42, how that can take place???? how does duet board detect failure???
                                                      is there something i can test on the board?
