BLTouch won't deploy.
Try adding a recovery time using the R parameter in the M558 command, e.g. R0.5 will delay 0.5 seconds between deploying the probe and probing. If that works, you can reduce the R parameter to find the minimum that works reliably.
I'm quite sure I have a bad BLTouch. The pin seems to stick 75% of the time half the time, and 90% of the time it works half the time. >_<
But I've added R0.5 to introduce a pause and A2 to probe twice. I've been able to generate a new compensation map that doesn't have spikes. It still fails a few probes but the map is much smoother.
Now when I print a leveling test pattern it adapts for the raised corner. 0.3mm on the first layer is pretty brutal.
Question about using the A parameter to multi touch. Does it discard erroneous values or average them out? Is it possible to completely ignore values above a certain amount and reprobe as a means of error rejection? Repetier firmware that I come from has a function like that where probe values above 2mm by default are rejected.
Don't use A2, use either A1 or A3 or higher. A(n) for n>1 probes until 2 consecutive probes are within the allowed tolerance of each other up to a maximum of n, then takes the average of those two readings.
Alright, thanks. I understand how it works now. The Gcode wiki doesn't really specify.
Here's what I finally ended up with to get decent results with the BLTouch. My probe pin still gets stuck up most of the time, but when it does manage to work it seems to work alright.
Config.g
[c]; ############################
; 3 - ENDSTOPS AND ZPROBE
; ############################M574 X1 Y2 S0 ; Set active-low switches, low end endstop for X, high end endstop for Y, Add Z1 for endstop
M574 Z1 S2 ; Use zprobe and home to min
M307 H3 A-1 C-1 D-1 ; Unbind heater 3 pins for probe use.
M558 P9 X0 Y0 Z1 H5 F100 T2000 A4 R0.5 ;I1 ; P9 for BLTouch, dive height 5mm, probe speed 100, travel speed 2000, 4 taps, pause 0.5 sec
G31 X-43.87 Y0 Z1.582 P25 ; probe offset from nozzle, p is trigger value, set low for bltouch, set Z=0 for testing
M557 X0:280 Y0:280 S10 ; Define mesh grid
M376 H10 ; Taper off compensation over 10mm of height[/c]Homeall.g
[c]; homeall.g
; called to home all axes
;; BLTouch prep so we don't catch the probe pin on the edge of the bed
M280 P3 S160 I1 ; Alarm Release and Push-Pin UP just in case it's in alarm and deployed
M402 ; Retract probe just in case it's down; Home XY for Z homing
G91 ; relative positioning
G1 Z5 F200 S2 ; Lower bed 5mm to ensure it is below the switch trigger height
M913 X50 Y50 ; set X Y motors to 50% of their normal current for homing
G1 S1 X-350 Y305 F4000 ; course home X or Y
G1 S1 X-350 F4000 ; course home X
G1 S1 Y305 F4000 ; course home Y
G1 X2 Y-2 F1000 ; move away from the endstops
G1 S1 X-10 F200 ; fine home X
G1 S1 Y10 F200 ; fine home Y
M913 X100 Y100 ; set X Y motors to 100% of their normal current; Z homing section follows
G90 ; absolute positioning
G1 X175 Y130 F4000 ; Move x and Y axis over to bed center so probe is on top of bed
M558 A1 F400 ; Set single probing at faster feed rate
G30 ; Do a single probe to home our Z axis
M558 A3 F100 ; Set tripple probing at slower feed rate
G30 ; Probe again to get a more accurate position; XY Homing follows
M913 X100 Y100 ; set X Y motors to 100% of their normal current[/c]Homez is mostly the same.
Thanks for the help David.
Time to go shopping for another BLTouch or find a good mount for my piezo probe to use on my dbot.
I still wasn't satisfied with the repeatability of the probe and the pin would still get stuck in the body regularly meaning Z homing would fail far too often.
So I decided to take apart the BLTouch and check the pin.
There is a small H2.0 set screw in the top of the body which acts as the magnetic core for the coil. Unscrewing it lets the pin fall out the top. The pin appeared to be in good condition but it did feel a bit tacky and the top of the pin that makes contact with the core appeared to have a bit of oily residue on it.
I lightly sanded the pin with 2000 grit paper and cleaned it with alcohol. I also scuffed off the residue from the end of the pin and the core. Then I used a small cotton pad and rolled up a corner tightly and used alcohol to clean out the small hole for the pin and the threaded hole for the core as there seemed to be a bit of residue in there too.
Put it all back together and adjusted the core to be about where it was before.
Redid the zprobe trigger height calibration and the repeatability went from this
1.819
1.819
1.826
1.824
1.816
1.825
1.827
1.819
1.824
1.825
1.822 averageto this
1.802
1.805
1.804
1.806
1.803
1.8
1.793
1.798
1.803
1.792
1.8006 averageFar better. And so far the pin has not gotten stuck in the body causing it to go into alarm.
I'm glad you managed to fix it. Is it a genuine bltouch or a clone?
It's supposedly the real deal. I contacted Antclabs but got no reply. I guess I could try the Google+ group. They might be active there.
