Homing troble
  • Here is my config.g and homedelta.g when i try to home all motors move but only about 10mm or so
    The endstops seem right m119 shows low stop and when triggered show high stop for got the exact wording
    If i enter gcode to move x50 and them x-50 also do both in the y direction they moved fine
    just seems to be going to home its moving in the right direction when i home only in shot spurts
    so i figure i have something configured wrong
    Just setup the duet and fist attempt at homing I assume with delta it should be triggered at high end stops
    Thanks gary
    ; generated by RepRapFirmware Configuration Tool on Sun Mar 25 2018 16:56:23 GMT-0400 (Eastern Daylight Time)
    M665 R105.6 L288 B85 H315 ; Set delta radius, diagonal rod length, printable radius and homed height
    M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them
    M550 PGarys Kossel ; Set machine name
    M551 Pgorf ; Set password
    M552 S1 ; Enable network
    M586 P0 S1 ; Enable HTTP
    M586 P1 S0 ; Disable FTP
    M586 P2 S0 ; Disable Telnet
    M350 X32 Y32 Z32 E32 I0 ; Configure microstepping without interpolation
    M92 X200 Y200 Z200 E175 ; Set steps per mm
    M566 X1200 Y1200 Z1200 E1200 ; Set maximum instantaneous speed changes (mm/min)
    M203 X18000 Y18000 Z18000 E1200 ; Set maximum speeds (mm/min)
    M201 X1000 Y1000 Z1000 E1000 ; Set accelerations (mm/s^2)
    M906 X1800 Y1800 Z1800 E1800 I30 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 Z0 S1 ; Set minimum Z
    M574 X1 Y1 Z1 S1 ; Set active low endstops
    M307 H3 A-1 C-1 D-1
    M558 P2 H5 F120 T6000 ; Set Z probe type to modulated and the dive height + speeds
    G31 P25 X5 Y20 Z5.0 ; Set Z probe trigger value, offset and trigger height
    M557 R85 S20 ; Define mesh grid
    M106 P0 S1 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M563 P0 D0 H1 ; Define tool 0
    ; homedelta.g
    G91 ; relative positioning
    G1 S1 X322 Y322 Z322 F1800 ; move all towers to the high end stopping at the endstops (first pass)
    G1 X-5 Y-5 Z-5 F1800 S2 ; go down a few mm
    G1 S1 X10 Y10 Z10 F360 ; move all towers up once more (second pass)
    G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred
    G90 ; absolute positioning
    G1 X0 Y0 F6000 ; move X+Y to the centre
  • I tried setting M574 to x0 y0 z0 also x1 y1 z1 same results homes only 10mm when i make the changes they show up with m119
    as the reverse to what was m119 showed before the change
    the positon display on the duetweb shows x0.0 y0.0 z285.00 if i home all or g28 it shows x0.0 y0.0 z270.00
    Gary
  • could the motors be reversed even thought they are moving toward the top end stops just thinking and the output went from 285 to 270 if homing on delta shouldn't the values be getting higher not lower?
    Gary
  • got it working had to set m574 x2 y2 z 2 s0
    then reverse the motor direction it homed fine hit endstops backed up and went up again and stoped
    so i think i got over this problem on to the next one..
    Thanks gary
