M997 command
  • Connecting using S3D and send code M997 XX, I either get Binary not found or trying to connect:
    Attempting connection at \.\COM13…
    Testing plaintext communication protocol...
    READ: ok
    Connected to machine!
    SENT: T0
    READ: ok
    SENT: M105
    READ: ok T:B:-273.1
    SENT: M105
    READ: ok T:B:-273.1
    SENT: M105
    READ: ok T:B:-273.1
    SENT: M105
    READ: ok T:B:-273.1
    SENT: M997 S0
    READ: Error: Firmware binary "DuetWiFiFirmware.bin" not found
    READ: ok
    SENT: M997 S1
    READ: Trying to connect at 460800 baud: failed
    READ: Trying to connect at 230400 baud: failed
    READ: Trying to connect at 115200 baud: failed
    READ: Trying to connect at 74880 baud: failed
    READ: Error: Installation failed due to comm write error
    SENT: M997 S2
    Any help would be appreciated.
    Is the firmware binary in he /sys/ directory on the SD card?
  • Here the three bin files in the sys folder on SD card:
    DuetWebControl
    DuetWiFiFirmware-1.15c
    DuetWiFiServer
    The firmware needs to be renamed to:
    Also consider updating to version 1.1.6
  • I put the 1.16 firmware as well as the latest web and server. when I went to run the M997 all went well at least one solved.
    Thanks for the help
