Edge connector panel cutout
Is a file with the dimensions of the board layout available? How similar is the layout pattern of the plug connectors to v0.8.5?
If you mean the side with the USB connector etc. then it is identical to the 0.8.5 apart from the Ethernet connector being replaced by the WiFi antenna. I published an OpenScad file for a panel to fit either type at http://www.thingiverse.com/thing:965396.
Protip, you can use tinkercad to just cut out the board part of David's faceplate and place in a model specific to your needs.
Thank you David.
