    Y axis motors are out of Sync
    • Puppet172undefined
      Puppet172
      I am using the Duet WiFi and the Duex5
      I am building a 3d printer and i have two y axises on it and i have one the y axis driver and one on the other on the E1 Driver. At first they weren't moving in sync and we didn't know why. we originally thought it was the motor so we switched it out for one we knew was good and it still did it. the one that wasent moving enough was on the E1 driver so we thought it might be that even though i did the M584 command to map it as the y axis. so what we did was switch the wiring the one one the E1 driver now moves the right amount but the one on the Y axis doesnt.
      If anyone has any idea of what going on it would be a great help. and it you have any questions just ask.
      Thanks
      • T3P3Tonyundefined
        T3P3Tony administrators
        You need to post your config and homing files so we can have a look.
        www.duet3d.com
        • AlexLinundefined
          AlexLin
          Is this on 1.21 or 1.20?
            Puppet172
            ; Configuration file for Duet WiFi (firmware version 1.17 to 1.19)
            ; generated by RepRapFirmware Configuration Tool on Thu Mar 29 2018 21:22:13 GMT-0400 (Eastern Daylight Time)
            M667 S1 ; Select CoreXY mode
            M550 PUnderground Printing- Jumbo ; Set machine name
            M552 S1 ; Enable network
            M587 S"KQVQM" P"SVLFBZMC3PK8893X" ; Configure access point. You can delete this line once connected
            M586 P0 S1 ; Enable HTTP
            M586 P1 S0 ; Disable FTP
            M586 P2 S0 ; Disable Telnet
            M569 P4 S0 ; Drive 4 goes back
            M350 X32 Y32 Z32 E16 I1 ; Configure microstepping with interpolation
            M92 X160 Y80 Z4000 E420 ; Set steps per mm
            M203 X6000 Y6000 Z180 E1200 ; Set maximum speeds (mm/min)
            M201 X500 Y20 Z250 E250 ; Set accelerations (mm/s^2)
            M906 X800 Y800 Z800 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M208 X0 Y0 U0 Z0 S1 ; Set axis minima
            M208 X838.2 Y762 Z1117.6 S0 ; Set axis maxima
            M574 X1 Y2 S0 ; Set active low endstops
            M558 P0 H5 F120 T6000 ; Disable Z probe but set dive height, probe speed and travel speed
            M557 X15:823.2 Y15:747 S20 ; Define mesh grid
            M140 H-1 ; Disable heated bed
            M106 P1 S1 I0 F500 H T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
            M106 P2 S1 I0 F500 H T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
            M563 P0 D0 H1 ; Define tool 0
            ; Custom settings
            M584 X0 Y1:4 Z5:6:7:8:2 E3:9
            ; homex.g
            ; called to home the X axis
            G91 ; relative positioning
            G1 S1 X-843.2 F1800 ; move quickly to X axis endstop and stop there (first pass)
            G1 X5 F6000 ; go back a few mm
            G1 S1 X-843.2 F360 ; move slowly to X axis endstop once more (second pass)
            G1 Z-5 F6000 S2 ; lower Z again
            G90 ; absolute positioning
            ; homey.g
            ; called to home the Y axis
            G1 S1 Y767 F1800 ; move quickly to Y axis endstop and stop there (first pass)
            G1 Y-5 F6000 ; go back a few mm
            G1 S1 Y767 F360 ; move slowly to Y axis endstop once more (second pass)
            ; homez.g
            ; called to home the Z axis
            G1 X15 Y15 F6000 ; go to first probe point
            ;G91 ; relative positioning
            ;G1 Z5 F100 S2 ; lift Z relative to current position
            ;G90 ; absolute positioning
            ; homeall.g
            ; called to home all axes
            G1 S1 X-843.2 Y767 F1800 ; move quickly to X or Y endstop and stop there (first pass)
            G1 S1 X-843.2 ; home X axis
            G1 S1 Y767 ; home Y axis
            G1 X5 Y-5 F6000 ; go back a few mm
            G1 S1 Y767 ; then move slowly to Y axis endstop
            G1 X15 Y15 F6000 ; go to first bed probe point and home Z
            ;G1 Z5 F100 S2 ; uncomment this line to lift the nozzle after homing
              The order of the commands in your config.g is a problem, see https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_Main_configuration_file.
