    After installing new FW 1.21 wrong finishing gcode
    Firmware installation
    • Computigerundefined
      Computiger
      after installing new FW 1.21. I got trouble with my prints.
      If my print is ending my extruder is running endless in reverse direction.
      Is anything changed with FW doing?
      Here my End Script:
      [[language]]
      G91 ;relative positioning
      G1 E-1 F300  ;retract the filament a bit before lifting the nozzle
      G90 ;absolute positioning
      M104 S0 ;extruder heater off
      M140 S0 ;heated bed heater off (if you have it)
      G1 Y0 F9600
      G1 X0
      M84 ;steppers off
      M106 S0 ;Fan off
      • whosrdaddyundefined
        whosrdaddy
        are you using absolute extrusion (M82)? that would explain the issue you are having.
          Computiger
          Yes I have set M82 in my starting script. But I never changed it. Bevor I´ve installed FW1.21 everything was working well.
          Do I have to remove M82?
            whosrdaddy
            no just put M83 at the start of your end script.
            Not sure, maybe before 1.21 the firmware did this for you.
            I don't see anything related in 1.21 release notes, maybe David can answer this one…
              Computiger
              ok thank you. I will try it out 🙂
