    Driverless version
    Hardware wishlist
    1039
    • Kulitorum
      Kulitorum last edited by
      Can you please make a version of the board with no driver, just output step-direction-enable signals? - and with 15 or 20 channels, please.
      I am building a printer with the following configuration:
      6 Z-axis motors
      2 Y axis motors
      1 X axis motor
      1 nozzle rotation motor
      2 actuators to manipulate details on the printhead
      4 motors for feeding material
      I would like to add more stuff (like z-axis auto level) but I am limited in the amount of step/direction signals I can use.
      • T3P3Tony
        Wow, that is going to be some printer! In the short term, given how Z bed levelling works, can you just use 3 Z motors (possibly more powerful ones on external drivers) and the use the on board steppers for the 4 extruders and one of the manipulators?
        Duet Hardware Designer
        www.duet3d.com
        • Kulitorum
          Kulitorum last edited by Kulitorum
          Well, they are actually all servo motors and not steppers. This is why I am asking for a driverless version, so I can add three or four breakout boards and have balanced step/dir/enable for up to 20 channels.
          • Kulitorum
            This is the printer:
            • T3P3Tony
              Concrete printer V2! Why 6 independent Z motors?
              www.duet3d.com
              Kulitorum 1 Reply Last reply Reply Quote 0
              • Kulitorum
                Kulitorum @T3P3Tony last edited by
                @t3p3tony so I can do independent z-motor auto leveling, of cause, just like I do on my 300x300x450 printer. Home the machine, move head close to the leadscrews, change config to only move one motor, and auto-level that one, continue to all 6.
                • T3P3Tony
                  If your gantry is stiff then do you not need to do only 3 points? Slave the other three motors? Would that work?
                  www.duet3d.com
                  • Kulitorum
                    I can do a manual calibration, as I have done until now, just saying that it would be nice with a version of the duet with more channels for future printer builds.
                    Or at least one with all 10 channels available in one or two expansion plugs.
                    Kulitorum
                    • T3P3Tony
                      Got it! btw we have 12 channels (two more on the CONN_LCD) header.
                      www.duet3d.com
