    Mesh Grid Offset?
    • ZeroedByteundefined
      ZeroedByte
      ZeroedByte 8 Apr 2018, 15:37
      I'm trying to get the auto bed leveling figured out on my delta.
      My inductive sensor sits 40mm on the +y axis.
      The issue I'm running into is, when I set my radius to like 70, it only probes half the bed.
      The whole -y side on zero doesn't seem to get probed.
      I changed the G31 offset in config.g, and that's the only place I've run a G31.
      What am I missing? 😞
      One day my printer will work without making my life a nightmare :D
        Please post your config.g file.
          ZeroedByte
          ; Configuration file for Duet WiFi (firmware version 1.17 to 1.19)
          ; generated by RepRapFirmware Configuration Tool on Fri Apr 06 2018 17:56:30 GMT-0600 (Mountain Daylight Time)
          M555 P5 ; Set firmware compatibility to look like Repetier
          M665 R138 L346.06 B60 H190.65 ; Set delta radius, diagonal rod length, printable radius and homed height
          M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them
          M550 PSeth's Delta ; Set machine name
          M552 S1 ; Enable network
          M587 S"Gandy Network" P"kittenrules" ; Configure access point. You can delete this line once connected
          M586 P0 S1 ; Enable HTTP
          M586 P1 S0 ; Disable FTP
          M586 P2 S0 ; Disable Telnet
          M92 X200 Y200 Z200 E895 ; Set steps per mm
          M566 X1200 Y1200 Z1200 E1200 ; Set maximum instantaneous speed changes (mm/min)
          M203 X18000 Y18000 Z18000 E1200 ; Set maximum speeds (mm/min)
          M201 X1000 Y1000 Z1000 E1000 ; Set accelerations (mm/s^2)
          M906 X1000 Y1000 Z1000 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 Z0 S1 ; Set minimum Z
          M574 X2 Y2 Z2 S1 ; Set active high endstops
          M558 P1 I1 X0 Y0 Z0 H5 F1400 T6000 ; Set Z probe type to unmodulated, the axes for which it is used and the dive height + speeds
          G31 P500 X0 Y40 Z0.608 ; Set Z probe trigger value, offset and trigger height
          M557 R70 S20 ; Define mesh grid
          M143 H0 S100 ; Set temperature limit for heater 0 to 100C
          M563 P0 D0 H1 ; Define tool 0
          ; Custom settings are not configured*
          I was also confused as to how to calibrate the endstop offset, I came from Repetier and the G132 offset tools.
            To put the nozzle at X0 Y-20 would require the nozzle to be at X0 Y-60 so it should at least probe that point. To probe X-20 Y-20 would put the nozzle at X-20 Y-60 which is 62.4mm from bed centre, so that should be probed too, same for X20 Y-20. But all the other points on that half of of the bed will be omitted because probing them isn't possible while keeping the nozzle within the bed radius.
