    Duet WIFI with Micron Cobra extruder temperature setting
    4.2k
    • Guyarosundefined
      Guyaros
      @saltypetz said
      So you want me to unhook the heater and put the meter on the heater wires. Is that what you want me to do?
      Yes, I want you to measure the resistance of the heater.
      Take a picture of your multimeter, with the measurement you did, so I can help you further.
      A reading of 600-700 it's not what it suppose to read.
      I don't think 2000k mode on your DMM (Digital Multi-Meter) is the correct mode.
      I think there is a language barrier between us, so please upload a picture.
      As I said, the extruder heater supposes to be connected directly to the Duet.
      But first, we need to investigate whats wrong with your wiring, because wires getting hot is not normal, and maybe you have kind of a shortage which causes a high current draw, or that you used very thin wires that aren't sufficient to handle high loads.
      • Saltypetzundefined
        Saltypetz
        There is no language barrier I understand what you want but I only have a junky meter at home. I can go get my Klein from my warehouse. But this meter will only work on 2000k nothing else.
        I put a URL from photobucket but nothing shows up.
        http://i1024.photobucket.com/albums/y301/loosewire1234/20180422_110352_zpshbnvi6rf.jpg
        I am still trying to up load the picture but it is a Greenlee DM-20.
        If I need to I will go pick up the meter now. Klein
        Thank you for your help
        • Guyarosundefined
          Guyaros
          Set the DMM to 200[ohm] mode.
          The resistance of heaters (in general) is in range of 1.5 to 6[ohm], so you will need to use the minimal range of your meter which is 200 in your case.
          If it's a faulty meter, then throw it away and get a new one.
          I'm trying to figure out what causing the wires to get hot.
          so please upload pictures of your wiring and connections to the Duet, this may help.
            Saltypetz
            Here are the pictures and I think it what you are asking me to do. I'm not a great electronics guy but i will try my best.
            http://i1024.photobucket.com/albums/y301/loosewire1234/20180423_144447_zpsj3ljlw1p.jpg
            http://i1024.photobucket.com/albums/y301/loosewire1234/20180423_144440_zpski3b8rjj.jpg
            In the wifi software when I try to turn on the heater where it says Sensors it drop down to 5 vovlt and the fan on the power supply shuts off. Do I need to go get a Atx power supply. If so what Atx sould I buy. With nothing on there It's only 18.9 volts. Could this be the whole problem.
              Saltypetz
              I just hooked up the atx power supply and the wires still get hot but now faster. The bed heats up no problem at all. Should I hook up the other hotend to see if it has the same problem. Let me know what you think.
              Thank you. You have been very help full.
                Saltypetz
                I can say for sure it not the Duet Wifi board I hooked it to a rambo and it has the same problem.
                  dc42 administrators @Saltypetz
                  @saltypetz, photbucket does not let other people see your photos unless you pay them. So please host your photos elsewhere.
                  It sounds to me that you may have a shorted heater cartridge.
                    Saltypetz
                    It you add this to google chrome it works no problem.
                    https://chrome.google.com/webstore/detail/photobucket-hotlink-fix/kegnjbncdcliihbemealioapbifiaedg?hl=en
                      Saltypetz
                      I hooked up the second heater it works no problem wires are not hot. Bad heater out of the box. the wires are not even warm.
                        Saltypetz
                        It is all working now. Till the next problem. I still have to do the end stops and the motors. So I'm sure I will be back.
                        Thank you for all the help
                          Saltypetz
                          How do I make optical sensor work on the Tevo Black Widow. There is one link but not to much information.
                          Guyaros and dc42 you have been great help for a beginner.
                          Thank you
