    recover the config file
    • alfqueen
      alfqueen last edited by
      Is there any way to recover the config file when it is accidentally deleted or do I have to start over again?
        If you edited it via the web interface and you are using a recent version of DWC then there will be a config.g.bak file in /sys on the SD card. Otherwise you will need to use the config tool to create a new one.
        • alfqueen
          thank you very much, I will look for it because my web version is the last and I save myself to start
            There is an option in DWC to select some or all of the files in /sys and save them in a zip file, for backup purposes. It's on the System Editor page.
            • alfqueen
              ok, thanks.
