    Delta Cable management
    2.6k
    • DjDemonDundefined
      DjDemonD
      So I've got a delta with a lot of cables:
      2 Cat 5 to the smart effector
      Drive cable to the Nimble extruder
      Water cooling hoses.
      I've done a quick video to show how the cables move around.
      https://youtu.be/JPLFe7PQp98
      Since my electronics are at the base of the machine, I loop the electronics and drive cable up and over and support them with a quality keychain retractor. The water cooling hoses just kind of coil up without any real drama all by themselves. I've had only one issue with wire breaks but I did do away with the 2x3 molex connector on the smart effector and just use Dupont 2 pins (24v hotend), and have had fewer issues since. I can move anywhere in the build volume and even position outside the (over-sized) bed area to do filament purges.
      I've tried flying extruder and whilst it probably beats bowden (although the margin is smaller since capricorn and pressure advance came along) it does add some mass (indirectly) and inertia and requires slightly smoother XY jerk/accel. Remote extruder wins for me. But the drive cable (and my water hoses) do the same thing they create "indirect" XY inertia, as such recent experimentation has seen me go back to 1000 accel for XY and 500 jerk.
      www.precisionpiezo.co.uk
      • Mystaundefined
        Mysta
        Got link for the retractable ring? Was just thinking how cool it would be to have something like that but with adjustable pull.
        DjDemonDundefined 1 Reply Last reply Reply Quote 0
        • DADIYundefined
          DADIY
          All my end stop cabling runs up each tower on the inside (the center of the extrusion) so its totally invisible, even at the top I cut a small section out of the back of the slot to allow the cable to turn and come back down to the stop switch, cabling to the effector and extruder run up the rear tower in the slot on the back. I'm using a slightly modified version of DC42's cable clip.
          The cable then passes over the top of the extruder and is spiral wrapped to the bowden tube down to the effector.
          Mystaundefined 1 Reply Last reply Reply Quote 0
          • Mystaundefined
            Mysta @DADIY
            @dadiy said in Delta Cable management:
            Yeah that sounds pretty standard. In my case my towers are 1.5 meters tall so you basically have 1.5 meters of cable that have to extend and then be able to home without getting in the way.
            Danalundefined DADIYundefined 2 Replies Last reply Reply Quote 0
            • Danalundefined
              Danal @Mysta
              @mysta said in Delta Cable management:
              Just for fun, how about some pics of your 1.5 M tall printer? In a different thread, if you prefer...
              • Mystaundefined
                Mysta @Danal
                @danal Sure! It's relevant in this thread - I'll grab some pics when I get home. Cables and stuff are still 'temporary'.
                • DADIYundefined
                  DADIY @Mysta
                  @mysta Yes, My towers are just over 1.7 meters tall so i just made up some cables before inserting the towers into the base.
                  For anyone interested there are a few build photos of my printer here - https://imgur.com/gallery/O1jtC I do need to add some of the finished printer but these give an idea of size and include the custom table I built which suspends the filament under the table on a lazy suzanne.
                  DADIYundefined 1 Reply Last reply Reply Quote 0
                  • DADIYundefined
                    DADIY @DADIY
                    Here’s two pics of it finished showing the cables etc.
                    https://imgur.com/gallery/AJyss
                    • Mystaundefined
                      Mysta @DADIY
                      @dadiy So your cables will reach the top like that without strain?
                      • DADIYundefined
                        DADIY
                        Yes. It’s been running like that for 6 months without issue. My biggest problem was the extruder. I bought a Titan extruder but it didn’t have the grip for my tube. I’m now on the Bondtech and never had a problem.
                        • DjDemonDundefined
                          DjDemonD @Mysta
                          I had a dig around for it but I can't find that particular unit for sale anymore. Its got a metal cable inside and is fairly sturdy, they're all fairly similar.
                          • Danalundefined
                            Danal
                            Here's a simple cell phone video of the "Stretch Magic" at work:
                            https://youtu.be/-FjWcPLWvKY
                            • Mystaundefined
                              Mysta @Danal
                              @danal said in Delta Cable management:
                              What bed heater is that?
                              Danalundefined 1 Reply Last reply Reply Quote 0
                              • Danalundefined
                                Danal @Mysta
                                Custom made by Keenovo. 590mm dia (glass is 604), 1400W on 120V (US standard), with built in 150C thermal protector. $240 USD, shipped.
                                Took some extra time because I ordered it JUST before China holiday.
                                The glass is a tabletop advertised as 24" by 3/8" (604mm by 9.5mm, roughly) on Amazon in the US. About $40 us shipped. I've been happy with it, although I'd note it is not very round. This makes no practical difference, so far, just a little bit of tweaking any time you remove it and replace it in the clips. It is reasonably flat, reflections of distant items on the surface show no noticeable distortion.
                                So the total bed was about $280 US. Considering I had ideas in my head ranging from cast aluminum plate to who knows what, that were going to be a lot more money, I'm very happy to report that the simple heater stuck to the glass (the heater came with a sticky layer) works GREAT!! Very happy with it. And, if I every damage the glass, it is the cheapest part.
