    Wifi Connectivity issue
    1.4k
    • catch.rahulmehtaundefined
      catch.rahulmehta
      I am having issues with my duet board connecting to wifi router. Over past several day I have tried several things but the issue keeps recurring to the points that I am frustrated with the board.
      Tried to recycle power, use on-board reset button, set specific channels on the router, moving the router just next to the board, Telnet to the board and update the wifi firmware
      Few of things that I noticed:
      1. after flashing the wifi the board most likely connects.
      2. In between the power cycles the wifi connects when the on-board wifi LED blinks and then turns solid. Mostly, the blue wifi led glows directly without blinking and in such cases the board is never connected to the router.
      Pls advice.
        1. Which main and wifi firmware versions are you using? Version 1.21 is recommended. The upgrade process from firmware 1.19 or later is straightforward, but from 1.18 or earlier it is more complicated.
        2. See https://duet3d.dozuki.com/Wiki/WiFi_disconnections_and_AJAX_timeout_errors.
          catch.rahulmehta
          I had upgraded to Firmware 1.21, however not sure if the wifi issues started prior to the upgrade or after....
          =========::details from web interface:===========
          Firmware Version: 1.21 (2018-03-21)
          WiFi Server Version: 1.21
          Web Interface Version: 1.21
          Few other points: once the wifi is connected I do not have any issues with disconnections / timeouts. the web interface responds for whole duration of print, even after 12+ hours
          Is there any reason for the wifi led on the board to glow solid blue directly before blinking a few times, after powering on
            I don't know why the blue LED would glow solid blue after turn on. Next time it happens, please send M122 via USB to get a diagnostic report. The "Wifi reset reason" may give us a clue.
            Are you using the internal 5V regulator to provide the 5V power, or are you providing 5V power by other means?
              catch.rahulmehta
              Today I had another round of issue with the wifi connectivity. As suggested, here are the M122 dumps
              M122<CR>
              Used output buffers: 1 of 32 (1 max)
              RepRapFirmware for Duet 2 WiFi/Ethernet version 1.21 running on Duet WiFi 1.02 or later
              Board ID: 08DDM-9FAM2-LW4S4-6JTDA-3S86K-KMSVX
              Static ram used: 16152
              Dynamic ram used: 100448
              Recycled dynamic ram: 2184
              Stack ram used: 3576 current, 4528 maximum
              Never used ram: 7760
              Last reset 00:01:13 ago, cause: power up
              Last software reset time unknown, reason: User, spinning module GCodes, available RAM 7760 bytes (slot 0)
              Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff
              Error status: 0
              Free file entries: 10
              MCU temperature: min 47.3, current 49.3, max 49.4
              Supply voltage: min 23.9, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0
              Slowest main loop (seconds): 0.000214; fastest: 0.000049
              MaxReps: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
              Scheduled moves: 0, completed moves: 0
              Bed compensation in use: none
              Segments left: 0
              Movement lock held by null
              http is idle in state(s) 0
              telnet is idle in state(s) 0
              file is idle in state(s) 0
              serial is ready with "M122" in state(s) 0
              aux is idle in state(s) 0
              daemon is idle in state(s) 0
              queue is idle in state(s) 0
              Code queue is empty.
              === Network ===
              HTTP sessions: 0 of 8
              • WiFi -
                Network state is starting
                WiFi module is disabled
                === Expansion ===
                ok
              M122<CR>
              Last reset 00:00:30 ago, cause: power up
              Error status: 0
              MCU temperature: min 46.5, current 49.3, max 49.4
              Supply voltage: min 23.8, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0
              Slowest main loop (seconds): 0.000212; fastest: 0.000049
              Segments left: 0
              === Network ===
              • WiFi -
                === Expansion ===
                ok
                RepRapFirmware for Duet 2 WiFi/Ethernet Version 1.21 dated 2018-03-21
              Executing config.g...Kinematics is CoreXY with axis factors X:1.000 Y:1.000 Z:1.000
              Error: M587: Failed to add SSID to remembered list
              HTTP is enabled on port 80
              FTP is disabled
              TELNET is enabled on port 23
              Done!
              M552 S0
              ok
              M122
              Stack ram used: 3576 current, 4476 maximum
              Never used ram: 7812
              Last reset 00:01:09 ago, cause: power up
              Error status: 0
              MCU temperature: min 46.6, current 50.5, max 50.8
              Supply voltage: min 0.4, current 0.5, max 0.7, under voltage events: 0, over voltage events: 0
              Driver 0: ok, SG min/max not available
              Driver 1: ok, SG min/max not available
              Driver 2: ok, SG min/max not available
              Driver 3: ok, SG min/max not available
              Driver 4: ok, SG min/max not available
              Slowest main loop (seconds): 0.000188; fastest: 0.000044
              Segments left: 0
              === Network ===
              • WiFi -
                === Expansion ===
                ok
                M552 S1
                Turn off the current WiFi mode before selecting a new one
                ok
                M552 S0
                ok
              M122
              Used output buffers: 1 of 32 (9 max)
              Stack ram used: 3576 current, 4548 maximum
              Never used ram: 7740
              Last reset 00:02:41 ago, cause: power up
              Error status: 0
              MCU temperature: min 50.5, current 51.3, max 51.5
              Supply voltage: min 0.4, current 0.5, max 0.5, under voltage events: 0, over voltage events: 0
              Slowest main loop (seconds): 0.003174; fastest: 0.000044
              Segments left: 0
              === Network ===
              • WiFi -
                === Expansion ===
                ok
              FTP is disabled
              Done!
                The wifi module has failed to respond to the startup command. One reason may be that you have a M587 command in config.g. Please remove that command.
                  catch.rahulmehta
                  Yes you are right, I have M587 in config.g
                  M550 PMy_Printer ; Set machine name
                  M552 S1 ; Enable network
                  M587 S"########" P"######" ; Configure access point. You can delete this line once connected
                  M586 P0 S1 ; Enable HTTP
                  M586 P1 S0 ; Disable FTP
                  M586 P2 S1 ; Enable Telnet
                    catch.rahulmehta
                    Removed M587 command but still continue to face issues...pls advice
                      If M122 always reports that the network state is Starting when you are having this problem and you run M122, and you are definitely running version 1.21 of both main and WiFi firmware, then I think the WiFi module is faulty. In which case, ask the supplier of your Duet to replace it.
                        catch.rahulmehta
                        Finally, had the wifi module replaced on Duet board and everything is a charm again. Thanks for the pointing out.
