    retract error duet wifi
    • niekoon001
      niekoon001 last edited by
      when i start a print the first part there is no problem, but when it retract it does 10 cm retraction when i asked a retract of 2 mm in the slicer.
      after did it do not bring the 10 cm of filament back.
      how can i solve this.
      mine configuration file:
      ; generated by RepRapFirmware Configuration Tool on Thu Mar 29 2018 22:31:50 GMT+0200 (CEST)
      M111 S0 ; Debug off Pnnn Debug module, Snnn Debug on/off
      G21 ; Work in millimetres
      M555 P1 ; Set firmware compatibility to look like RepRapFirmare
      M550 Pprusa large ; Set machine name
      M552 S1 ; Enable network
      M587 S"NKP" P"LesSWirE@NkP8" I10.0.0.236 J192.168.1.254 K255.255.255.0 ; Configure access point and IP addresses. You can delete this line once connected
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M569 P0 S1 ; Drive 0 goes forwards X
      M569 P1 S1 ; Drive 1 goes forwards Y
      M569 P2 S1 ; Drive 2 goes forwards Zleft
      M569 P3 S0 ; Drive 3 goes forwards E
      M569 P4 S1 ; Drive 2 goes forwards z right
      ; dual z drive
      M584 X0 Y1 Z2:4 ; three Z motors connected to driver outputs 2, 5 and 6
      M671 X-15:290 Y15:15 S0.5 ; leadscrews at rear left, front middle and rear right
      M92 X79 Y79 Z398 E159,5 ; Set steps per mm
      M566 X1000 Y1000 Z60 E120 ; Set maximum instantaneous speed changes (mm/min) Maximum jerk speeds mm/minute
      M201 X900 Y900 Z100 E3000 ; Set accelerations (mm/s^2)
      M203 X4000 Y4000 Z150 E1000 ; Maximum speeds (mm/min)
      M906 X1100 Y1100 Z800 E1200 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X-33 Y-70 Z0 S1 ; Set axis minima
      M208 X292 Y350 Z200 S0 ; Set axis maxima
      M574 X1 Y1 S0 ; Set active low endstops
      M558 P3 H2 F900 T500 ; Set Z probe type to ultrasonic and the dive height + speeds
      G31 P900 X40 Y0 Z0 ; Set Z probe trigger value, offset and trigger height
      M557 X15:290 Y15:290 S20 ; Define mesh grid
      M106 P0 S1 I0 F500 H1 T180 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M200 D1.75
      M563 P0 D0 H1 ; Define tool 0
      • T3P3Tony
        It is likely that your slicer is using absolute extrusions and you have configured the duet for relative extrusion. Relative extrusion is generally better so if you can change the slicer settings to use relative extrusion do that, otherwise add M82 in your start gcode or change the in config.g to M82
        Duet Hardware Designer
        www.duet3d.com
        • niekoon001
          i use cura slicer, i changed the starting script and the the option to relative extrution and still no change in print. i even change the config file to m82 code, with slicer is beter then cura for duet? i have this problem since i had problems to connect to the duet and i had to reinstal i installed now 2.0(RTOS)beta1+ (2018-04-12b1) version. shall i go back to the stable one.
            I suggest you either upgrade the main firmware to 2.0beta2 or revert to 1.21.
            If the problem persists, please provide a link to the GCode file you are trying to print.
            • niekoon001
              this solves the problem, now it retracts how it suppose to be.
