    Upload error, why? Maybe i must format SD?
    • FBG
      FBG last edited by
      1.21 Ethernet version.
      Everything is fine, but the 90% times than i upload file happen a error and i must do again.
      Some idea?
      My question is:
      In what format i must format the SD? FAT, FAT32, exFat?
      64kb or that?
      Thanks
        If you need to reformat the SD card, then for best results:
        • If the capacity of the card is 4Gb or less, select FAT16 format
        • If the capacity of the card is greater than 4Gb then you will have to use FAT32 format
        • In either case, use the largest cluster size possible, which is normally 64Kb.
        • FBG
          FBG last edited by
          I am using the SD than the DuetEthernet have, but finally i buy a new 4gb SD and with the new the problem is absolutely solved.
          Perhaps the ADATA brand is a wrong SD?
          • Nylkos
            Nylkos last edited by
            Possibly, but try M21, that would initialize the SD card.
            It happenned to me a few times and that usually work.
