    Restart a print after fault pause and timeout?
    1979
    • Legrand
      Legrand last edited by
      I was printing a rather large print at work over he weekend, and after about 40 hours of printing, the printer had a heater fault. Three hours later (10800 seconds), the console reported that the print was cancelled due to the un-cleared heater fault.
      I've read that you can resume a print using resurrect.g, but when I try to use M916 to reactivate, I receive an "unsupported command" error. Is there any way for me to salvage this print, or am I dead in the water?
      • Barracuda72
        Barracuda72 last edited by
        HAd the same Prob with a heater failure.
        Readon why i couldnt restart it, is a missing resurrect-prologue.g file.
        a resurrect.g file is there...and documentation isnt very clear about how to get the resurrect-prologue.g
        Or work that feature only with voltage drops?
        • Legrand
          I added the resurrect-prologue.g file to the sys folder when I was trying to get it restarted this morning, but it didn't make any difference.
            See https://duet3d.dozuki.com/Wiki/Setting_up_to_resume_a_print_after_a_power_failure.
            • Legrand
              I did that.
              The documentation says "... you can use command M916 to resume the print from where it stopped."
              As I stated above, I set up the file sys/resurrect-prologue.g, but when I sent the M916 command, I got an "unsupported command" error.
              I was guessing that this was because I didn't catch it in the first three hours?
              Is there some other way to restart the print?
                Are you running latest stable firmware i.e. 1.21?
                • Legrand
                  Yeah, 1.21.
                    In that case, the "unsupported command" error will have included the G- or M-code that isn't supported. Please provide the full error message.
                    • Legrand
                      M916 isn't supported. It's saying "M916 command is not supported".
                        dc42 administrators @Legrand last edited by
                        @legrand said in Restart a print after fault pause and timeout?:
                        It sounds as if you are not actually running firmware 1.21. Please send M115 and report the response.
                        • Legrand
                          Here's the relevant info:
                          Mysta 1 Reply Last reply Reply Quote 0
                          • Mysta
                            Mysta @Legrand last edited by
                            @legrand Go to 'G-Code Console' and enter M115
                            • Legrand
                              Legrand last edited by Legrand
                              It's right there.... in my last post... the third picture. I'll post it here again, but this time not as a picture?
                              5:57:08 AM M115
                              FIRMWARE_NAME: RepRapFirmware for Duet FIRMWARE_VERSION: 1.21 ELECTRONICS: Duet 0.85 FIRMWARE_DATE: 2018-03-21
                                It's because you are using an older Duet, which doesn't support M916 because the older Duets don't have power fail detection. Try this instead:
                                M98 Presurrect.g
