    Impossible to flash my Duet wifi
    Firmware installation
    1859
    • M0DE
      M0DE last edited by M0DE
      I received my duet a week ago, I installed it and configured it, I was able to print but two days ago I lost the wifi and tried to reconfigure it with the Yat but it did not respond or recognize the Duet as an external device, I tried to install the driver again but it has been impossible for what I searched in the forum and I have seen a post in which they commented that the card should be flashed again, I have tried in several ways, with external power, without it, removing all the cables connected to the plate, with two different computers, several cables and it has been impossible, I tried Bossa and the same, I can not flash the board, any suggestions? in the attached video you can see the process.
      Thank you
      https://www.youtube.com/watch?v=E76Fq1krF34&feature=youtu.be
        What is the file size of the DuetWiFiFirmware.bin that you are trying to flash? It should be over 300Kb. I think your file may be much shorter than that. The download area is https://github.com/dc42/RepRapFirmware/releases.
        M0DE 1 Reply Last reply Reply Quote 0
        • M0DE
          M0DE last edited by
          The sd card must be inserted when i'm flashing with Sam-ba or it doesn't matter?
            dc42 administrators @M0DE last edited by
            @m0de said in Impossible to flash my Duet wifi:
            It doesn't matter.
            • M0DE
              M0DE @dc42 last edited by
              @dc42 Hi, I tried with the file you sent me and nothing again, i don't know if i'm missing something or what but i'm not able to flash the duet.
              https://www.youtube.com/edit?o=U&video_id=PNkdRx7adss
                Your video link doesn't work for me.
                Did you check the size of the DuetWiFiFirmware.bin file?
                • M0DE
                  M0DE last edited by
                  Hi, yes the size is 372, try with this link please: https://youtu.be/PNkdRx7adss
                    At 1:41 in the video SAM-BA reported "Sent file and memory do not match". So programming failed.
                    Please try using Bossa instead. Instructions are at the end of https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Fallback_procedure_Num_3.
                    • M0DE
                      Nothing, i don't know if i'm doing something wrong.
                      https://youtu.be/A-Cq0FEep74
                      This is my Duet i'm using the Duetwififirmware, this is right?
                        Yes, DuetWiFiFirmware.bin or Duet2CombinedFirmware.bin from the 1.21 release area is correct for that Duet.
                        What happens if you write the firmware using Bossa, but after that click Verify?
                        • Dougal1957
                          Dougal1957 last edited by
                          do the windows drivers need to be loaded before the port will be recognised after flashing?
                          could that be why it isn't being recognised afterwards?
                            I would expect Device Manager to report "Unknown device" if the Duet was detected but no driver for it was found. You do have a couple of unknown devices showing, but they are flagged "Dispositivo base del sistema" which according to Google Translate means "Base device of the system".
                            • M0DE
                              M0DE last edited by
                              @dougal1957 said in Impossible to flash my Duet wifi:
                              If i try to install de driver in the ports you can see nothing happen, i don't know what's that but is not the due because if i plug or unplug the Duet that ports still there and if i install the Duet driver an error message appear.
                              https://youtu.be/9Yts6R1Ay5Y
                                Thank you, Bossa is getting verify errors, just like SAM-BA did. Please ask your suppler to replace the Duet under warranty.
                                • M0DE
                                  M0DE last edited by
                                  I bought it on your web, how can I send the Duet?
                                    See https://duet3d.com/warranty.
