    M290 problems
    • pnokel
      pnokel last edited by
      I am trying to set Z baby steps in my config.g:
      M290 R0 Z1.23 (for example)
      That results in an offset of 1mm (as displayed in DWC and in the gcode console).
      M290 R0 Z0 does reset the offset to 0mm.
      A manual M290 R0 Z1.23 results in the same offset: 1mm
      https://www.dropbox.com/s/0a6txpzsxvjgik2/Screenshot 2018-04-24 11.21.55.png?dl=0
      What does work is setting the offset step by step:
      https://www.dropbox.com/s/os20xd2rge3pzd7/Screenshot 2018-04-24 11.23.21.png?dl=0
      M290 Z1.6 (offset is now 1mm)
      M290 Z0.23 (offset is now 1.23mm)
      There is no difference in using Z or S as parameter for M290.
      The up and down buttons in DWC are working as expected.
      Am I missing something here?
      Best regards,
      Paul
      pnokel 1 Reply Last reply Reply Quote 0
      • pnokel
        pnokel @pnokel last edited by
        Forgot to mention: I am on version 1.21
        • Jackal
          Jackal last edited by
          Each babystep adjustment is limited to -1mm to 1mm, because it's only for minor adjustment during printing/calibration.
          You shouldn't need it in your config.g.
          What are you trying to achieve?
          • pnokel
            I am just using babystepping as a workaround until I figure out my probe offsets. I understand that this is not what baby stepping is for.
            The behaviour of the M290 command was just different from what I expected. I think there should be a hint in the documentation what the command can do. It confused me quite a bit that I can add even .01mm with relative babysteps, but only full mm with absolute steps.
              There is an intentional limit on normal (relative) babystepping of +/- 1.0mm. However, that limit is also being applied unintentionally to absolute babystepping. I will fix this in the next firmware release.
