    Filament change during Bed heating not working as expected
    780
    • mloidl
      mloidl last edited by
      Yesterday i have found a really strange behaviour (maybe bug) on my duet.
      When i try to preheat my heat bed from the PanelDue (lets say to 40°C) and during the heat-up phase i want to load a filament, the hotend is reaching it's target temperature specified in the load-gcode but does not loading the filament until the bed reached it's target temperature (40°C).
      Since heating up my bed takes a long time (~10min to 65°C) it try to use this time for doing other stuff (like changing or loading the filament).
      Is this the desired behavior or i'm doing something wrong?
      my load.g:
      G10 S225 ; Set current tool temperature to 225C
      M116 ; Wait for the temperatures to be reached
      M291 P"Feeding filament..." R"Loading PETG" S0 T0 ; Display new message
      G1 E5 F600 ; Feed 10mm of filament at 600mm/min
      G1 E45 F3000 ; Feed 45mm of filament at 3000mm/min
      G1 E10 F300 ; Feed 15mm of filament at 300mm/min
      G4 P1000 ; Wait one second
      G1 E-5 F1800 ; Retract 5mm of filament at 1800mm/min
      M400 ; Wait for moves to complete
      M292 ; Hide the message
      G10 S0 ; Turn off the heater again
      I'm using RepRapFirmware 1.21 on a core-xy printer (Hypercube)
      Thanks in advance.
      Best regards,
      Martin
      • Jackal
        Jackal last edited by
        https://duet3d.dozuki.com/Wiki/GCode#Section_M116_Wait
        Try M116 P1
        mloidl 1 Reply Last reply Reply Quote 0
        • mloidl
          mloidl @Jackal last edited by
          @jackal
          Thank you for your response. I'll check it when i'm at home today.
          I'm pretty sure this is the problem.
          Best regards,
          Martin
            The M116 command without parameters waits for all temperatures to be reached, including the bed. Use e.g. M116 P0 to wait only for the tool 0 heater(s) to reach operating temperature.
            • mloidl
              mloidl @dc42 last edited by
              Just checked to documentation and sucessfully tested it with M116 P0.
              Thank you for your help.
              • zerspaner_gerd
                zerspaner_gerd last edited by
                Is there a command where just waiting for the tools (T0&T1) without waiting for the bed?
                Board: Duet WiFi 1.03 | Firmware Version: 3.1.1 | WiFi Server Version: 1.23 | Web Interface Version: 3.1.1
                  Phaedrux Moderator @zerspaner_gerd last edited by
                  @zerspaner_gerd "Recent versions of RepRapFirmware also allow a list of the heaters to be specified using the 'H' parameter, and if the 'C' parameter is present, this will indicate that the chamber heater should be waited for."
                  zerspaner_gerd 1 Reply Last reply Reply Quote 0
                  • zerspaner_gerd
                    zerspaner_gerd @Phaedrux last edited by zerspaner_gerd
                    @phaedrux Thank you for your prompt reply.
                    So then
                    M116 H1:2
                    Will try it
