Problema di configurazione wifi
Hello everyone I do not know if this topic is already present in the forum, I did not find anything about it,
I followed the guide (https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7) to configure the wifi of the duet card with terminal yat, the problem occurs when I have to enter the command ls /dev/tty.* I send the command but the card does not respond, I try to send the command M552 and tells me: WiFi module is idle <LF> ok <LF>, then I sent the command M552 S1 and tells me: ok <LF> WiFi reported error: no known networks found <LF> WiFi module is idle <LF>, someone helps me to understand how to solve the problem, I'm sorry for the language but I'm Italian and I'm using a translator.
thanks everyone in advance
Have you looked at this section? It helps with connecting to a network.
https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7#s9
proprio quella sezione ho guardato ma inviando il comando ls /dev/tty.* la scheda non mi restituisce nulla, mentre la scheda risponde con i normali comandi G, se invio il comando M552 S1 la scheda mi dice, WIFI REPORTED ERROR: NO KNOW NETWORK FOUND, WIFI MODULE IS IDLE, perche?
Send M587 with no parameters via USB, and check that is reports the SSID of your Wifi network exactly right with the correct upper and lower case letters, because SSIDs are case-sensitive.
perfetto risolto!!!!
Grazie a tutti
adesso ho un grosso problema con i finecorsa non riesco a capire bene la loro logica di funzionamento
@giuseppe said in Problema di configurazione wifi:
Grazie a tuttiSadly I don't understand Italian (just some French and German and a few words of Dutch, Spanish and Hungarian), but I think the jist is that it is working now.
