    The AX NPN inductive probe
    • npm1
      npm1 last edited by
      Are these type of inductive probes compatible with the duet, I do have BX variant coming in soon.
      I know i covered this in a previous post, but that diagram i created didn't work.
      I tried all three different diodes on the probe, and yet it seemed as though the signal wasn't being picked up.
      So i tracked back to an idea presented on another website where the signal and power(12v) are linked to together using a 10k OHM resistor, and a diode is connected in line with the signal connector.
      I gonna try this any way.
      But please let me know.
      Love the learning curve as i can now solder.
      Ender 5 pro(LGXextruderddewith e3d revo rapid changer) with fly rrf e3 and a standard prusa mk3, both siting air-tight in a ikea kitchen cabinet.
        Please provide a link to the datasheet for the inductive sensor that you want to use.
        npm1 1 Reply Last reply Reply Quote 0
        • npm1
          npm1 @dc42 last edited by
          detection range: 4mm±10%
          set detection: 0~3.6mm
          standard detection object: Iron 15×15×1mm
          response frequency: DC:0.5Hz AC:25Hz
          its a 300ma, NC type of probe
            You can use both PNP and NPN inductive sensor with the Duet, see https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe.
            In the M558 command, use I1 if using an NPN output NO or a PNP output NC sensor. Use I0 (or omit the I parameter) if using a NPN output NC or a PNP output NO sensor.
            • npm1
              @dc42 OK is omit I0/I1 the same as not including in the line.
              I tried that i.e. m558 with the I1 and without it no luck
