Z-offset Issue(Probably Me)
HI, hope someone can help me.
Ive built a hypercube and having a strange issue with my z-offset.
ive gone through the setup procedures with everything including the z-offset(using a bltouch btw). bltouch is working as it supposed to. Anyways, regardless of what i mak my z-offset t always goes to the same offset. is there any commands i have in my config file that may be over riding the z-offset.Thanks in advanced
; generated by RepRapFirmware Configuration Tool on Mon Mar 26 2018 07:38:31 GMT+0200 (South Africa Standard Time); General preferences
;M83 ; ...but relative extruder moves
M555 P1 ; Set firmware compatibility to look like RepRapFirmareM667 S1 ; Select CoreXY mode
M550 PMy printer ; Set machine name
M552 S1 ; Enable network
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M92 X80 Y80 Z800 E418.5 ; Set steps per mm
M566 X500 Y500 Z12 E120 ; Set maximum instantaneous speed changes (mm/min)
M203 X9000 Y9000 Z600 E3600 ; Set maximum speeds (mm/min)
M201 X700 Y700 Z250 E750 ; Set accelerations (mm/s^2)
M906 X1200 Y1200 Z1000 E1000 I30 ; Set motor currents (mA) and motor idle factor in per cent
M208 X295 Y295 Z365 S0 ; Set axis maxima; Endstops
M574 X1 Y1 S1 ; Set active high endstops
M574 Z1 S2 ; Use zprobe and home to min; Z-Probe
M307 H3 A-1 C-1 D-1 ; use pin 3 on header for bltouch
M558 P9 X0 Y0 Z1 H5 F100 T2000 ; P9 for BLTouch, dive height 5mm, probe speed 100, travel speed 2000, 4 taps, pause 0.5 sec
G31 X25 Y0 Z2.70 P25 ; probe offset from nozzle, p is trigger value, set low for bltouch, set Z=0 for testing
M557 X45:280 Y45:280 S40 ; Define mesh grid; Heaters
M305 P0 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 0
M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
M143 H1 S280 ; Set temperature limit for heater 1 to 280C; Fans
M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 D0 H1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Automatic saving after power loss is not enabled
G31 Zxxxx changes the height of Z in relationship to probe trigger. I change this to get a good first layer.
I know. Thats the "Z-offset"im talking about. changing that makes no difference to my setup for some reason. trying to figure it out.
Thanks though
Do you have another G31 command in your config-override.g file?
How are you homing Z?
Hey DC42
Thanks fot taking time to look at my issue, hopefully you can see somethingThis is in my config-override.g file
; Heater model parameters
M307 H0 A90.0 C700.0 D10.0 S1.00 V0.0 B1
M307 H1 A326.3 C141.1 D6.3 S1.00 V24.1 B0
M307 H2 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H6 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H7 A340.0 C140.0 D5.5 S1.00 V0.0 B0And this is my homeall file
; homeall.g
; called to home all axes
G91 ; relative positioning
G1 Z5 F600 S2 ; lift Z relative to current position
M98 P/macros/Deployprobe.g ; deploy mechanical Z probe
G1 S1 X-300 Y-300 F1800 ; move quickly to X or Y endstop and stop there (first pass)
G1 S1 X-300 ; home X axis
G1 S1 Y-300 ; home Y axis
G1 X5 Y5 F6000 ; go back a few mm
G1 S1 X-300 F360 ; move slowly to X axis endstop once more (second pass)
G1 S1 Y-300 ; then move slowly to Y axis endstop
G1 Y15 X15 F500 ; MOVE OUT A FEW MM
G1 S1 Z-300 F1800 S1 ; move Z down stopping at the endstop
G90 ; absolute positioning
G92 Z2.5 ; set new Z position
;G1 Z5 F100 S2 ; uncomment this line to lift the nozzle after homingM98 P/macros/retractprobe.g ; retract mechanical Z probe
and Home Z
; homez.g
; called to home the Z axis
G1 X25 Y25 F1000 S2
G1 S1 Z-370 F1800 ; move Z down until the switch triggers
G92 Z2.5 ; set Z position to trigger height
M98 P/macros/Retractprobe.g
G1 ZX-25 Y-25 F600 S2; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G1 Z5 F100 S2 ; lift Z relative to current position
;G90 ; absolute positioning
I don't see a G30 probe command in there. That would explain why your trigger height isn't being set, you aren't measuring it. You are currently using the zprobe as an endstop.
Replace the z movement section with a G30.
Thanks. What do you mean, "replace the z movement section with G30". Replace G31 with G30?
@saadiqj I mean that where you use G1 S1 Z-370 to move the bed use G30 to call for a probe instead.
https://duet3d.dozuki.com/Wiki/Gcode#Section_G30_Single_Z_Probe
Here is my HomeAll.g for comparison.
; homeall.g ; called to home all axes ; ; BLTouch prep so we don't catch the probe pin on the edge of the bed ; M280 P3 S160 I1 ; Alarm Release and Push-Pin UP just in case it's in alarm and deployed M402 ; Retract probe just in case it's down ; Home XY for Z homing ; G91 ; relative positioning G1 Z5 F200 S2 ; Lower bed 5mm to ensure it is below the switch trigger height M913 X50 Y50 ; set X Y motors to 50% of their normal current for homing G1 S1 X-375 Y305 F4000 ; course home X or Y G1 S1 X-375 F4000 ; course home X G1 S1 Y305 F4000 ; course home Y G1 X2 Y-2 F1000 ; move away from the endstops G1 S1 X-10 F200 ; fine home X G1 S1 Y10 F200 ; fine home Y M913 X100 Y100 ; set X Y motors to 100% of their normal current ; Z homing section follows ; G90 ; absolute positioning G1 X190 Y90 F4000 ; Move x and Y axis over to bed center so probe is on top of bed ; Set lower speeds for homing M566 Z5 ; Set maximum instantaneous speed changes (mm/min) (Jerk) M203 Z350 ; Set maximum speeds (mm/min) M201 Z100 ; Set maximum accelerations (mm/s^2) ; Probe the bed ; M558 A1 F350 ; Set single probing at faster feed rate G30 ; Do a single probe to home our Z axis M558 A10 F100 ; Set tripple probing at slower feed rate G30 ; Probe again to get a more accurate position ; Set normal speeds again M566 Z60 ; Set maximum instantaneous speed changes (mm/min) (Jerk) M203 Z600 ; Set maximum speeds (mm/min) M201 Z600 ; Set maximum accelerations (mm/s^2) ; Move X and Y back Home ; G1 X0 Y270
