    My prints are in mirror, but the axis are good.
    2784
    • mickey30m
      mickey30m last edited by
      Hi Everyone,
      i am new to Duet 3D but what a amazing board, i finetune everything now.
      But i have some strange problems.
      my printer prints in mirror.
      I have a Tevo Tarantula but when i print a
      a calibration cube come out like this
      My bed is 200 mm -->
      and 280 depth
              ______ x _______
             |           Z            Y            <------- the letter z is also in mirror
      but when i move my axis everything is correct.
      my x axis homed on the left
      my y axis (bed) home to the back of the printer
      my + is to the right en - to the left
      the stl is make in simplyfi 3d and is a good file, i printed many times on my mks board.
      maybe someone have a idea?
      i will make some pictures and post it
      many thanks
        Can you post your config file?
        • mickey30m
          mickey30m last edited by mickey30m
          Off course
          0_1524951247148_config.g
          top view
            You have set up your machine with a left hand coordinate system, when it needs to be right hand. When you jog the Y axis, which way does it move? If +X is to the right, then +Y should be to the rear.
            • mickey30m
              x+ is x axes to the right
              y+ is y axes to the rear
              tjb1 1 Reply Last reply Reply Quote 0
              • mickey30m
                Why can i not place photos?
                i put it between the ( ) but it dont work
                then as link ;'-)
                https://photos.app.goo.gl/pCRox2M78Bu8JuUcA
                  Are you sure that you don't have mirroring enabled in S3D?
                  mickey30m 1 Reply Last reply Reply Quote 0
                    That is quite good for low cost delta printer mechanics, and you should be able to get reasonable prints from it. But I think you have some sticking in the mechanism. Check that the motor current is set to at least 60% of the rated current of the motors, and consider lubricating the joints (I use silicone grease for that).
                    mickey30m 2 Replies Last reply Reply Quote 0
                    • mickey30m
                      mickey30m @dc42 last edited by
                      @dc42 i am sure off that
                      • mickey30m
                        @dc42 the motors are 1,7 a. and run on 0.8 i believe.
                        some config with mks board, everything was working good...
                          dc42 administrators @mickey30m last edited by
                          @mickey30m said in My prints are in mirror, but the axis are good.:
                          On my computer, S3D defaults to a left-hand axis system - which is completely wrong - unless I check the Y box next to "Flip build table axis" in the G-Code tab. See https://msdn.microsoft.com/dynimg/IC155562.gif and check that both your printer and S3D are using a right hand coordinate system.
                          • mickey30m
                            strange,
                            okay i change in s3d flip y axis see picture, but now the screen is mirrored in S3d 😉
                            i going to print a cube and lett you know...
                            https://photos.app.goo.gl/z7oLq11BbEYI90Qk1
                            • mickey30m
                              now he prints exactly like the screen in S3D .. But it is also in mirror 😉
                              how can i see if my printer is left hand orientated. ??
                              or what can i do
                              • mickey30m
                                @dc42 it is a Tevo Tarantula, with a lot of improvements.
                                thats why i want the duet on it...
                                he can print very nice...
                                this are prints from a couple of months ago
                                the blue one is flex material
                                https://photos.app.goo.gl/DKidRcL9RQoxkv5BA
                                  Looking from in front of the printer, if +X moves the print head towards the right and +Y moves the print head towards the rear (or moves the bed towards the front, if the printer has a moving bed) then it is right handed.
                                  • mickey30m
                                    okay than its right handed
                                    but my prints are still in mirror
                                    https://photos.app.goo.gl/04YhgIgobaxp101N2
                                      Which way do the axes point in S3D's representation of the bed?
                                      • mickey30m
                                        @dc42 https://photos.app.goo.gl/9eERlnDNRr4xtmty1
                                        • tjb1
                                          tjb1 @mickey30m last edited by
                                          Are you saying that pressing Y+ is moving the bed towards the back of the printer?
                                          • timcurtis67
                                            timcurtis67 last edited by
                                            Can you post the first 20 or so lines of the gcode program you are trying to run?
                                            Does the program call out X- moves when they should be X+ moves?
                                            Or post the model somewhere and someone can try slicing it for you and send you the gcode file to try running. To see if you still have a mirror issue then. That would help rule out the printer firmware.
                                            • mickey30m
                                              https://www.rsruitersport.nl/Starman_32.gcode
                                              https://www.rsruitersport.nl/xyzCalibration_cube.stl
                                              G90
                                              M82
                                              M106 S0
                                              M140 S60
                                              M190 S60
                                              M104 S225 T0
                                              M109 S225 T0
                                              G92 E0
                                              G1 E-3.6000 F3000
                                              G1 Z1.420 F3000
                                              ; layer 1, Z = 0.22
                                              T0
                                              ; tool H0.220 W0.400
                                              ; skirt
                                              G1 X71.613 Y105.968 F9600
                                              G1 Z0.220 F3000
                                              G1 E0.0000 F900
                                              G92 E0
                                              G1 X71.931 Y105.796 E0.0119 F1800
                                              G1 X73.307 Y105.319 E0.0599
                                              G1 X73.485 Y105.274 E0.0659
                                              G1 X74.325 Y105.132 E0.0939
                                              first lines after the ; code
                                              from starman_32.gcode
                                              timcurtis67 1 Reply Last reply Reply Quote 0
                                              • mickey30m
                                                mickey30m @tjb1 last edited by
                                                @tjb1
                                                i will post a movie when the printer is done with my print.
                                                i need to make a few adjustments to print very damn tastic 😉
                                                but the problem with mirror image is difficult to solve 🙂
                                                than i want to make the z hop beter , firmware retract.
                                                now i do it in the stl (gcode)
                                                • timcurtis67
                                                  timcurtis67 @mickey30m last edited by
                                                  G90
                                                  M82
                                                  M106 S0
                                                  M140 S60
                                                  M190 S60
                                                  M104 S225 T0
                                                  M109 S225 T0
                                                  G92 E0
                                                  G1 E-3.6000 F3000
                                                  G1 Z1.420 F3000
                                                  ; layer 1, Z = 0.22
                                                  T0
                                                  ; skirt
                                                  G1 Z0.220 F3000
                                                  G1 E0.0000 F900
                                                  G92 E0
                                                  So by reading one of the first actual print moves (G1 X71.613 Y105.968 F9600) the print head should be going to the RIGHT 71.613mm and the print bed should move TOWARDS you 105.968.
                                                  If it isn't moving like this then the firmware is configured wrong.
                                                  • mickey30m
                                                    mickey30m @timcurtis67 last edited by
                                                    @timcurtis67 IT is moving like this.
                                                    That's are the problem. But IT prints in mirror.
                                                    I try already swap cables change config
                                                    Print another stl but i dont know anymore
                                                      Does your printer home Y to the rear or to the front? In Your S3D screenshot it shows all axes homing to min, but is that correct? Your config.g
                                                      Can you post your homing files?
                                                      I suspect that you have an axes direction reversed and are correcting for it in the homing files.
                                                      I would go through your motor configuration and testing again with this as a reference.
                                                      https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_Movement_section
                                                      Ensure that each motor turns the way you want it to and homes in the direction you want it to. It may help if you identify which drive axis is assigned to each Drive Number in the config.
                                                      This is what you had posted in your config.g. Is that still accurate?
                                                      M569 P0 S0        ; Drive 0 goes backwards
                                                      M569 P1 S1        ; Drive 1 goes forwards
                                                      M569 P2 S0        ; Drive 2 goes backwards
                                                      M569 P3 S1        ; Drive 3 goes forwards
                                                      M569 P4 S0									; Drive 4 goes forwards (Z2 in the E1)
                                                      M350 X16 Y16 Z16 E16:16 I1                                                      ; Configure microstepping with interpolation
                                                      M92 X80 Y80 Z400 E420:400                                                       ; Set steps per mm
                                                      M566 X900 Y900 Z12 E120:12                                                      ; Set maximum instantaneous speed changes (mm/min)
                                                      M203 X4800 Y4800 Z960 E1200:960                                                 ; Set maximum speeds (mm/min)
                                                      M201 X500 Y50 Z500 E250:500                                                     ; Set accelerations (mm/s^2)
                                                      M906 X800 Y800 Z800 E800:800 I30                                                ; Set motor currents (mA) and motor idle factor in per cent
                                                      M84 S30        ; Set idle timeout
                                                      ;Dual Z
                                                      M584 X0 Y1 Z2:4									; Two Z motors connected to driver outputs 2 and 4
                                                      M671 X0:140 Y100:100 S0.5							; leadscrews at mid left, and mid right
                                                      M208 X0 Y0 Z0 S1        ; Set axis minima
                                                      M208 X200 Y280 Z200 S0                                                          ; Set axis maxima
                                                      M574 X1 Y2 S0 									; X home to min. Y home to max. NC microswitches.
                                                      M574 Z1 S1 									; Define Z to use Probe. Home to Min.
