My prints are in mirror, but the axis are good.
4.4k
    That is quite good for low cost delta printer mechanics, and you should be able to get reasonable prints from it. But I think you have some sticking in the mechanism. Check that the motor current is set to at least 60% of the rated current of the motors, and consider lubricating the joints (I use silicone grease for that).
    undefined 2 Replies Last reply 30 Apr 2018, 10:07 Reply Quote 0
      mickey30m @dc42
      @dc42 i am sure off that
      undefined 1 Reply Last reply 30 Apr 2018, 10:22 Reply Quote 0
        mickey30m @dc42
        @dc42 the motors are 1,7 a. and run on 0.8 i believe.
        some config with mks board, everything was working good...
          dc42 administrators @mickey30m
          @mickey30m said in My prints are in mirror, but the axis are good.:
          On my computer, S3D defaults to a left-hand axis system - which is completely wrong - unless I check the Y box next to "Flip build table axis" in the G-Code tab. See https://msdn.microsoft.com/dynimg/IC155562.gif and check that both your printer and S3D are using a right hand coordinate system.
            mickey30m
            strange,
            okay i change in s3d flip y axis see picture, but now the screen is mirrored in S3d 😉
            i going to print a cube and lett you know...
            https://photos.app.goo.gl/z7oLq11BbEYI90Qk1
              mickey30m
              now he prints exactly like the screen in S3D .. But it is also in mirror 😉
              how can i see if my printer is left hand orientated. ??
              or what can i do
                mickey30m @dc42
                @dc42 it is a Tevo Tarantula, with a lot of improvements.
                thats why i want the duet on it...
                he can print very nice...
                this are prints from a couple of months ago
                the blue one is flex material
                https://photos.app.goo.gl/DKidRcL9RQoxkv5BA
                  Looking from in front of the printer, if +X moves the print head towards the right and +Y moves the print head towards the rear (or moves the bed towards the front, if the printer has a moving bed) then it is right handed.
                    mickey30m
                    okay than its right handed
                    but my prints are still in mirror
                    https://photos.app.goo.gl/04YhgIgobaxp101N2
                      Which way do the axes point in S3D's representation of the bed?
                      undefined 1 Reply Last reply 30 Apr 2018, 16:32 Reply Quote 0
                        mickey30m @dc42
                        @dc42 https://photos.app.goo.gl/9eERlnDNRr4xtmty1
                        undefined 1 Reply Last reply 1 May 2018, 11:42 Reply Quote 0
                          tjb1 @mickey30m
                          x+ is x axes to the right
                          y+ is y axes to the rear
                          Are you saying that pressing Y+ is moving the bed towards the back of the printer?
                          undefined 1 Reply Last reply 30 Apr 2018, 18:18 Reply Quote 0
                            timcurtis67
                            Can you post the first 20 or so lines of the gcode program you are trying to run?
                            Does the program call out X- moves when they should be X+ moves?
                            Or post the model somewhere and someone can try slicing it for you and send you the gcode file to try running. To see if you still have a mirror issue then. That would help rule out the printer firmware.
                              mickey30m
                              https://www.rsruitersport.nl/Starman_32.gcode
                              https://www.rsruitersport.nl/xyzCalibration_cube.stl
                              G90
                              M82
                              M106 S0
                              M140 S60
                              M190 S60
                              M104 S225 T0
                              M109 S225 T0
                              G92 E0
                              G1 E-3.6000 F3000
                              G1 Z1.420 F3000
                              ; layer 1, Z = 0.22
                              T0
                              ; tool H0.220 W0.400
                              ; skirt
                              G1 X71.613 Y105.968 F9600
                              G1 Z0.220 F3000
                              G1 E0.0000 F900
                              G92 E0
                              G1 X71.931 Y105.796 E0.0119 F1800
                              G1 X73.307 Y105.319 E0.0599
                              G1 X73.485 Y105.274 E0.0659
                              G1 X74.325 Y105.132 E0.0939
                              first lines after the ; code
                              from starman_32.gcode
                              undefined 1 Reply Last reply 30 Apr 2018, 20:06 Reply Quote 0
                                mickey30m @tjb1
                                @tjb1
                                i will post a movie when the printer is done with my print.
                                i need to make a few adjustments to print very damn tastic 😉
                                but the problem with mirror image is difficult to solve 🙂
                                than i want to make the z hop beter , firmware retract.
                                now i do it in the stl (gcode)
                                  timcurtis67 @mickey30m
                                  G90
                                  M82
                                  M106 S0
                                  M140 S60
                                  M190 S60
                                  M104 S225 T0
                                  M109 S225 T0
                                  G92 E0
                                  G1 E-3.6000 F3000
                                  G1 Z1.420 F3000
                                  ; layer 1, Z = 0.22
                                  T0
                                  ; skirt
                                  G1 Z0.220 F3000
                                  G1 E0.0000 F900
                                  G92 E0
                                  So by reading one of the first actual print moves (G1 X71.613 Y105.968 F9600) the print head should be going to the RIGHT 71.613mm and the print bed should move TOWARDS you 105.968.
                                  If it isn't moving like this then the firmware is configured wrong.
                                  undefined 1 Reply Last reply 30 Apr 2018, 21:27 Reply Quote 0
                                    mickey30m @timcurtis67
                                    @timcurtis67 IT is moving like this.
                                    That's are the problem. But IT prints in mirror.
                                    I try already swap cables change config
                                    Print another stl but i dont know anymore
                                      Does your printer home Y to the rear or to the front? In Your S3D screenshot it shows all axes homing to min, but is that correct? Your config.g
                                      Can you post your homing files?
                                      I suspect that you have an axes direction reversed and are correcting for it in the homing files.
                                      I would go through your motor configuration and testing again with this as a reference.
                                      https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_Movement_section
                                      Ensure that each motor turns the way you want it to and homes in the direction you want it to. It may help if you identify which drive axis is assigned to each Drive Number in the config.
                                      This is what you had posted in your config.g. Is that still accurate?
                                      M569 P0 S0 ; Drive 0 goes backwards
                                      M569 P4 S0 ; Drive 4 goes forwards (Z2 in the E1)
                                      M350 X16 Y16 Z16 E16:16 I1 ; Configure microstepping with interpolation
                                      M92 X80 Y80 Z400 E420:400 ; Set steps per mm
                                      M566 X900 Y900 Z12 E120:12 ; Set maximum instantaneous speed changes (mm/min)
                                      M203 X4800 Y4800 Z960 E1200:960 ; Set maximum speeds (mm/min)
                                      M201 X500 Y50 Z500 E250:500 ; Set accelerations (mm/s^2)
                                      M906 X800 Y800 Z800 E800:800 I30 ; Set motor currents (mA) and motor idle factor in per cent
                                      M84 S30 ; Set idle timeout
                                      ;Dual Z
                                      M584 X0 Y1 Z2:4 ; Two Z motors connected to driver outputs 2 and 4
                                      M671 X0:140 Y100:100 S0.5 ; leadscrews at mid left, and mid right
                                      M208 X200 Y280 Z200 S0 ; Set axis maxima
                                      M574 X1 Y2 S0 ; X home to min. Y home to max. NC microswitches.
                                      M574 Z1 S1 ; Define Z to use Probe. Home to Min.
                                      undefined 1 Reply Last reply 30 Apr 2018, 22:54 Reply Quote 0
                                        mickey30m @Phaedrux
                                        @phaedrux
                                        this is how it is now.
                                        everything is done like the wiki.
                                        M569 P0 S0 ; Drive 0 goes backwards - x motor
                                        M569 P1 S1 ; Drive 1 goes forwards - y motor
                                        M569 P2 S0 ; Drive 2 goes backwards - left z motor
                                        M569 P3 S1 ; Drive 3 goes forwards - extruder 1
                                        M569 P4 S0 ; Drive 4 goes forwards (Z2 in the E1) - right z motor
                                        5_1525128618496_homez.g
                                        4_1525128618496_homey.g
                                        3_1525128618496_homex.g
                                        2_1525128618496_homeall.g
                                        1_1525128618496_config.g
                                        0_1525128618495_bed.g
                                          So it definitely looks like you have it configured for Y max homing, but simplify 3D is set for Y min homing.
                                          17 out of 36
