BLTouch issues
after spending some hours with setting up my BLTouch, i got it working, but i dont think its working the it's supposed to be. Some problems i ran into:
- the probe did not deploy automatically when homing with G30 (M558 P9 was set which should automatically deploy/retract i assumed) so i added M401/402 commands
- after triggering the pin immediately retracted, fell do again hitting the glass, then retracted due to my M402 i guess and moved on to probe the next point where it deployed again
Shouldnt the probe deploy, retract as it hits the surface, deploy again and move to the next probing point without the retract move before travelling to next point? As mentioned earlier, the probe does not deploy automatically in Mode P9. Here are my bed.g, homez.g and config.g files.
Thanks in advance for any help, if someone can even understand my rather confusing text.
Video: https://youtu.be/JmPQB6cXZaE
config.g
; generated by RepRapFirmware Configuration Tool on Sat Mar 31 2018 15:11:41 GMT+0200 (CEST); General preferences
M83 ; ...but relative extruder moves; Network
M550 PDrucker ; Set machine name
M551 P123 ; Set password
M552 S1 ; Enable network
M587 S"xxx" P"xxx" ; Configure access point. You can delete this line once connected
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M569 P0 S1 ; X axis
M569 P1 S0 ; Y axis
M569 P2 S0 ; Z axis
M569 P3 S1 ; Extruder
M92 X80 Y80 Z2133.333 E871 ; Set steps per mm
M566 X1200 Y1200 Z50 E150 ; Set maximum instantaneous speed changes (mm/min)
M203 X6000 Y6000 Z180 E1200 ; Set maximum speeds (mm/min)
M201 X500 Y500 Z250 E250 ; Set accelerations (mm/s^2)
M906 X800 Y800 Z800 E800 I10 ; Set motor currents (mA) and motor idle factor in per cent
M84 S2 ; Set idle timeout; Axis Limits
M208 X145 Y175 Z180 S0 ; Set axis maxima; Endstops
M574 Y1 S1
M574 X1 S3
M574 Z1 S2; Z-Probe
M307 H3 A-1 C-1 D-1 ; BLTouch
M558 P9 X0 Y0 Z1 H5 F100 T2000 ; BLTouch used by Z axis, dive height 5mm, mode 9
G31 X0 Y0 Z1.53 P50 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment; Heaters
M143 H0 S100 ; Set temperature limit for heater 0 to 100C
M305 P1 T100000 B4725 C7.06e-8 R4700 ; Set thermistor + ADC parameters for heater 1
M143 H1 S250 ; Set temperature limit for heater 1 to 250C; Fans
M106 P0 S0.7 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 D0 H1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0CT0 ; Select first tool
bed.g
; bed.g (automatic bed compensation) (called by softkey in webcontrol, heightmap loaded with G29 S1)
G28 ; home all axes first
M557 X5:145 Y5:145 S35 ; Define mesh grid
G29 S0 ; run probing and calculate bed compensation
homez.g
; homez.g (SENSOR)
G91 ; relative positioning
G1 Z3 F100 S2 ; lift Z 3mm relative to current position
G90 ; absolute positioning
G1 X80 Y80 F3000 ; go to first probe point
M401
M402
Edit: i commented m401 and 402 out and the problem is still the same as seen in the video. maybe its because my z moves up too slowly after triggering?
Just to clarify, do you have the servo deploy and retract commands in the deploy probe.g and retract probe.g files?
Are you using firmware 1.21?
The pin popping back out like that seems to be normal behavior now. It isn't a probing activation. Mine does that too and there have been posts from others with the same thing.
Does the probe function otherwise?
@phaedrux yes i have those commands inside the files. and yes i am using 1.21.
the probe does function so i guess i shouldnt worry too much about it. t
thanks for your fast response!
@ab4d So does G30 automatically deploy the probe as required or do you have to do it manually still? It should be autpmatic.
@phaedrux it deploys it automatically now. the only thing that bothers me, as i said, is the pin popping back out immediately after triggering instead of staying inside while homing
and
the pin NOT staying out while moving to next probe point,
but as you said, that seems to be normal behaviour
