Z Motors not moving
@sfinlon said in Z Motors not moving:
@dc42 stock anet a8 motors.
I did just order 2 new nema17’s and new couplers because I can’t tell what part is failing.Perhaps they are high-inductance motors that need to be connected in parallel instead of in series.
@sfinlon I can see two errors in your config (having just converted my own Anet A8 to Duet I made the same mistakes):
For one Z Motor direction needs to be reversed so change
to
and (assuming you have not changed the lead screws) also your steps/mm for Z axis are wrong. Change
M92 X80 Y80 Z4000 E420 ; Set steps per mm
to
M92 X80 Y80 Z400 E420 ; Set steps per mm
If you are still using the original 16-tooth pulley also the values for X and Y need to be 100 instead of 80. And using the original extruder gear these steps would be 95 instead of 420.
I had my steps/mm for Z calculated wrong (should have trusted Marlin config more) and had set it to 1600 which led to horrible asymmetric jumping of the Z axis. I am glad that it did not break or bend anything (at least I hope it did not).
P.S.: Here is my complete section of drive settings for all motors, rods and leadscrews being stock. Note that motor currents are currently set to their rated current. I will tune this probably tonight to a lower value.
; Drives M569 P0 S1 ; Drive X goes forwards M569 P1 S1 ; Drive Y goes forwards M569 P2 S0 ; Drive Z goes backwards M569 P3 S1 ; Drive E0 goes forwards M350 X16 Y16 Z16 E16 I1 ; Configure microstepping with interpolation M92 X100 Y100 Z400 E95 ; Set steps per mm M566 X600 Y600 Z18 E300 ; Set maximum instantaneous speed changes (mm/min) M203 X24000 Y24000 Z480 E3000 ; Set maximum speeds (mm/min) M201 X2000 Y2000 Z100 E10000 ; Set accelerations (mm/s^2) M906 X900 Y900 Z900 E900 I20 ; Set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout
One last addition: if you are also still using stock thermistors you could use the following settings:
M305 P0 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 0 M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
@dc42 "Perhaps they are high-inductance motors that need to be connected in parallel instead of in series."
That's exactly what I was thought too! Because if I left the jumpers on Z2 and only plugged one or the other motor in to Z1 that one motor was fine.
So I cut the wire, and spliced and soldered them together in parallel, and plugged the combined connector in to Z1 and left the jumpers on Z2 and it's working fantastically now.
@wilriker I know marlin had the steps per mm at 100 100 400 for x y z but wasn’t sure if the steppers changed any of that.
I modified the thermistors like you exampled though.
What do you use for a bed offset? It looks like I’m not quite centered.
@sfinlon I have my minima for X -35mm and Y -7mm. Might be slightly different on your machine but generally should be quite close.
Except for my mistake with Z direction and steps/mm I basically started with the settings from Marlin and they are working.
As I said, I would tune my motor currents and can already say that 50% (=450mA) for X, Y and Z (which by the way is regularly wired in series in my setup) work fine for print speed of 75mm/s and travel speed of 120mm/s. I only tested this in a dry-run yet, though.
By dry-run I mean I took the GCODE of one of my prints that I knew contained parts of all kinds (long slow and fast extrusions, long travels, diagonals, circles, zig-zag infill with fast direction changes, etc) and reduced it to two selected layers Andrew removed heating and all extrusions. Then I set my motor currents and "printed" this file and checked that there are no skipped steps. I have not yet fine-tuned extruder motor but at it to around 750mA for now.P.S.: if anyone is interested in my dry-run file, I am happy to she l share it.
@wilriker A dry-run file is a good idea. I'd be interested in seeing it.
@phaedrux Here you go with my dry-run file Testmoves.gcode.
I used https://www.thingiverse.com/thing:2895187 as a basis, sliced it with 0.2mm layer height (all the settings are appended by Cura at the end of the file anyway) and removed all layers except 11 and 16. After that I removed all Ennn parts of movements and also cleaned up start code to not heat up anything. It only does a
G28
at the beginning and aM18
at the end.This has some pretty gnarly paths with fast zig-zag infill that are going to shake your printer - also a good way to find loose screws or other rattling things.
EDIT: Your printer needs at least to be able to reach
X175 Y175
to be able to use this - even though this has not to be a printable area as no extrusions happen.
