    add two nema 23 in series
    • Pablo
      Pablo last edited by
      Can I add two nema 23 in series in Z axis and in Y axis.
      2.2A and 2.6 ohms each motor . thanks
      • mgrimes1907
        mgrimes1907 last edited by
        You could use an extra driver to make a second Zaxis. I have 4 on mine.
        • Danal
          Danal last edited by Danal
          Series takes same current, but cuts torque at each motor in half. (EDIT: Torque is same at low speeds; the downside is the speed at which torque begins to fall off is halved)
          Parallel draws double current (quite often beyond capacity of a single driver).
          Best way on Duet is almost always to use one driver per motor, and configure to make them work together.
            dc42 administrators @Danal last edited by
            @danal said in add two nema 23 in series:
            No, series gives you the same torque at low speeds - unless the motors have unusually high resistance - but the maximum speed you can run the motors at before the torque starts to drop is halved. There is a calculator at reprapfirmware.org to work this out.
            Danal 1 Reply Last reply Reply Quote 0
            • Danal
              Danal @dc42 last edited by
              @dc42 said in add two nema 23 in series:
              Aha! Thank you... I almost didn't post that, something didn't quite feel right.
              Excellent clarification.
