    Problem with uploaded stl file
    Firmware developers
    • mickey30m
      mickey30m last edited by
      Hi there,
      when i upload a stl file (drag and drop on the upload button)
      the duet goes crazy, i get then a http error and the duet can not connect anymore.
      i must power off a couple of minutes to activate the duet again.
      are there more people have this?
      • resam
        resam last edited by
        Why are you uploading an STL file?
        The Duet requires g-code files to print. You need to use a software to slice your STL models into g-code.
        • mickey30m
          i know
          but is er no protection or warning?
          • ShadowX
            ShadowX last edited by ShadowX
            Yeah, the protection is when it goes crazy. Try sending an .EXE file or .HTML as your next test.
            • mickey30m
              It was not a test. I select the wrong file.
              But then i het problems with the board.
              I though maybe is it a good Idea to protect that OR something.
              I dont think i AM the first one that select a stl file 😉
                Probably would be a good idea to have some error rejection built in to the upload function. Maybe this can get moved to the DWC/firmware wishlist section?
