    Change of Webfronted default settings in config possible ?
    • Pumlux
      Pumlux last edited by
      on older firmwares on the duet 0.8.5 it was possilbe to edit some files on the SD card to have e.g. the language setting and some more GUI settings set
      permanently. With the new web GUI everything is placed in a .bin file. ( Not sure if this was the modell.js or the language.xml file)
      I miss the possiblility to change the default language and some GUI behavior. I start always with Englisch and ATX power controll missing.
      Is there still a way to say the GUI the default settings ?
      Anyone who can provide a hint to me ?
      Using a own build of a Mendel Max , Duet Wifi, Bed 8 mm Aluminium PEI 500 x 280 x 400 230 V 850 W, original E3D Chimera hotend with bowden length 700 mm, since short time with a BL-Touch, Steppers : mostly Nema 17 and one Nema 23 for Y-axis
      • tomasf
        tomasf last edited by
        It would be nice if the web interface saved its settings server-side instead of in client-side storage. There are obviously endpoints for uploading and downloading files, so there should be nothing technical preventing this 🙂
        • Jackal
          Jackal last edited by
          You can down DuetWebControl from https://github.com/chrishamm/DuetWebControl
          Edit the files as desired and build it with the build.sh script
          • T3P3Tony
            Server side setting storage is a feature request for RRF/DWC -
            Duet Hardware Designer
            www.duet3d.com
