Getting conected after changes
  • Hi I have had my duet 3d wifi for some years now but have changed my printer and laptop I just can' t seem to remember how to get going again. i can see a control panel I have always used but it bis a simulation and wont let me do anything please help.
    Regards
    Mike
    Which firmware version is your Duet WiFi running?
  • Hi, firmware 1.7 Reprapfirmware.
    mike
    That's quite old, and there were major changes at version 1.19. I suggest you upgrade to version 1.21. See https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Upgrading_to_DuetWiFiFirmware_1_Num_19 for the special procedure for upgrading from pre-1.19 to 1.19 or later. You can use that procedure to migrate directly to 1.21, but read the upgrade notes for 1.21 and the versions you skipped.
  • Is there any way I can buy a card with this done? I am the worlds worst at doing this sort of thing I am more of a build man than a techno man. Thanks Mike
    It's not just a matter of changing the SD card because two sets of firmware on the Duet need to be changed too.
  • This is were I have got to,
    Still don't understand what this means
    READ: G90
    Testing binary communication protocol...
    Connected to machine!
    SENT: d501015e
    READ: d501015e
    This printer only supports binary commands.
    Disconnected.
    Attempting connection at \.\COM3...
    Testing plaintext communication protocol...
    READ: G90
    SENT: d501015e
    READ: d501015e
    this is what I get when I try to use M997 S1
    Mike
    @mikesplane said in Getting conected after changes:
    READ: G90
    SENT: d501015e
    READ: d501015e
    Disconnected.
    READ: G90
    SENT: d501015e
    READ: d501015e
    Mike
    What program are you using to communicate with the Duet? I don't recognise those responses.
