    Print cancels at the start of a new print
    • GeckoBox3D
      GeckoBox3D last edited by
      For some reason I've come across a weird error after installing the new firmware.
      My prints often cancel themselves before they have even started, weirdly though, this only happens on about half of the prints and is more likely to happen after I've already done a print, but it has also done it on the first print.
      my routine: I set temps manually, slice file and then upload it to the web interface. The homing process then starts and the print will cancel after the X axis homes and then it will turn the heaters off etc, just like ending a print. My starting script in the slic3r is just G28.
      my Homeall file:
      M84 E0:1 ; Extruder motor off
      G91 ; Relative positioning
      ;G1 Z5 F6000 S2 ; Lift Z
      G1 Y-195 F1800 S1
      G1 X-195 F1800 S1 ; Move towards X and Y axis endstops (first pass)
      G1 X5 Y5 F6000 ; Go back a few mm
      G1 X-195 Y-195 F360 S1 ; Move slowly to axis endstops once more (second pass)
      G1 Z-200 S1 F100 ; move Z down until the switch triggers
      G1 Z20 S1 F100 ; Move Z up 20mm
      G92 Z0.10 ; tell the firmware that we are at Z=0.10mm
      G90 ; absolute mode
      My homeX file:
      G91
      G1 Z5 F6000 S2
      G90
      G91
      G1 X5 F6000
      G90
      G1 X-250 F360 S1
      G91
      G1 Z-5 F6000 S2
      G90
      Any help appreciated.. I have checked the forums and this is a head scratcher
        It could mean that the Duet is resetting. Next time it happens, please run M122 and post the report here.
        • GeckoBox3D
          M122 just tells me that a file was selected for printing. nothing else happens.
          using USB and S3D yields this:
          SENT: M122
          READ: === Diagnostics ===
          READ: Used output buffers: 5 of 32 (11 max)
          READ: === Platform ===
          READ: RepRapFirmware for Duet 2 WiFi/Ethernet version 1.21 running on Duet WiFi 1.0 or 1.01
          READ: Board ID: 08DAM-999TL-MQ4S8-6JTDJ-3SJ6N-16BBW
          READ: Static ram used: 16152
          READ: Dynamic ram used: 100504
          READ: Recycled dynamic ram: 2128
          READ: Stack ram used: 3576 current, 6632 maximum
          READ: Never used ram: 5656
          READ: Last reset 55:12:08 ago, cause: power up
          READ: Last software reset at 2018-04-22 18:17, reason: User, spinning module GCodes, available RAM 5784 bytes (slot 0)
          READ: Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff
          READ: Error status: 8
          READ: Free file entries: 10
          READ: SD card 0 detected, interface speed: 20.0MBytes/sec
          READ: SD card longest block write time: 0.0ms
          READ: MCU temperature: min 35.6, current 35.8, max 36.7
          READ: Supply voltage: min 11.9, current 12.0, max 12.2, under voltage events: 0, over voltage events: 0
          READ: Driver 0: standstill, SG min/max not available
          READ: Driver 1: standstill, SG min/max not available
          READ: Driver 2: standstill, SG min/max not available
          READ: Driver 3: standstill, SG min/max not available
          READ: Driver 4: standstill, SG min/max not available
          READ: Date/time: 2018-05-10 18:04:05
          READ: Slowest main loop (seconds): 0.179110; fastest: 0.000112
          READ: === Move ===
          READ: MaxReps: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
          READ: Scheduled moves: 0, completed moves: 0
          READ: Bed compensation in use: none
          READ: Bed probe heights: 0.000 0.000 0.000 0.000 0.000
          READ: === Heat ===
          READ: Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1
          READ: Heater 0 is on, I-accum = 0.0
          READ: Heater 1 is on, I-accum = 0.4
          READ: === GCodes ===
          READ: Segments left: 0
          READ: Stack records: 1 allocated, 0 in use
          READ: Movement lock held by null
          READ: http is idle in state(s) 0
          READ: telnet is idle in state(s) 0
          READ: file is idle in state(s) 0
          READ: serial is ready with "M122" in state(s) 0
          READ: aux is idle in state(s) 0
          READ: daemon is idle in state(s) 0
          READ: queue is idle in state(s) 0
          READ: autopause is idle in state(s) 0
          READ: Code queue is empty.
          READ: === Network ===
          READ: Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
          READ: HTTP sessions: 2 of 8
          READ: - WiFi -
          READ: Network state is running
          READ: WiFi module is connected to access point
          READ: Failed messages: pending 0, notready 0, noresp 0
          READ: WiFi firmware version 1.21
          READ: WiFi MAC address 5c:cf:7f:2c:27:94
          READ: WiFi Vcc 3.38, reset reason Turned on by main processor
          READ: WiFi flash size 4194304, free heap 15992
          READ: WiFi IP address 192.168.1.147
          READ: WiFi signal strength -63dBm, reconnections 0, sleep mode modem
          READ: Socket states: 0 0 0 0 0 0 0 0
          READ: === Expansion ===
          • Stealthy_TT
            Stealthy_TT last edited by
            What’s your bed size?
            GeckoBox3D 1 Reply Last reply Reply Quote 0
            • GeckoBox3D
              GeckoBox3D @Stealthy_TT last edited by
              @stealthy_tt
              195mm^2
              • Stealthy_TT
                Try adding more bed size in the Homeall.g for example here is a modified section of yours.
                G1 Y-220 F1800 S1
                G1 X-220 F1800 S1 ; Move towards X and Y axis endstops (first pass)
                G1 X-220 Y-220 F360 S1 ; Move slowly to axis endstops once more (second pass)
                Even though your bed size is 195mm in some conditions it may take more than 195mm of travel to make it to the endstop while homing.
                I noticed that in your homex.g you gave the X position 250mm of travel during homing of just X, you can use that number in homeall also if you feel like it.
