    duet wifi connection issues
    Firmware installation
    1767
    • IanWalton
      IanWalton last edited by
      Long story ... just some background
      Bought tevo little monster, bought duet wifi board, for a while life was good. had car accident, tlm too big now, am in chair, cant reach top of printer on work surface. or build surface if on floor.
      bought Cr10, for a while life was really good, way better than the TLM. one day the cr10 extruder driver decided to stop working. thought stuff it and stick the duet wifi board in it, i want to go 2+ extruders soon anyway
      got going wiring it in and when 3/4 way through i thought ive got enough done to start testing as i go
      no such luck, i cannot get the blasted thing to connect via wifi. i reinstalled all the firmware files via duets webpage,
      M115 command returns ''Duet 2 wifi / ethernet firmware version 1.21 duet wifi version 1.02 or later
      i follow duets web page, getting connected, but the board doesnt seem to respond right.
      M552 returns wifi module is being started
      M587 returns failed to retrieve network list
      im lost, need help, please, tearing my hair out and my 3d printing is the only thing keeping me sane
      any advice welcome, even if ive screwed up, need to know where to move forward
      • IanWalton
        M587 S"awesomewifi" P"dummypassword" returns failed to add SSID to remembered list
          1. What DuetWiFiServer firmware version is installed? If Duet Web Control won't connect, then to find out send M122 over USB.
          2. If you run M587 with no parameters, does it return a list of known WiFi networks?
          • IanWalton
            === Diagnostics ===<LF>Used output buffers: 1 of 32 (1 max)<LF>=== Platform ===<LF>RepRapFirmware for Duet 2 WiFi/Ethernet version 1.21 running on Duet WiFi 1.02 or later<LF>Board ID: 08DDM-9FAM2-LW4S4-6J1D8-3SD6R-T3SZX<LF>Static ram used: 16152<LF>Dynamic ram used: 100248<LF>Recycled dynamic ram: 2384<LF>Stack ram used: 3576 current, 4528 maximum<LF>Never used ram: 7760<LF>Last reset 01:25:57 ago, cause: power up<LF>Last software reset time unknown, reason: User, spinning module GCodes, available RAM 7688 bytes (slot 2)<LF>Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff<LF>Error status: 0<LF>Free file entries: 10<LF>SD card 0 detected, interface speed: 20.0MBytes/sec<LF>SD card longest block write time: 0.0ms<LF>MCU temperature: min 28.8, current 30.8, max 31.4<LF>Supply voltage: min 12.2, current 12.2, max 12.3, under voltage events: 0, over voltage events: 0<LF>Driver 0: standstill, SG min/max not available<LF>Driver 1: standstill, SG min/max not available<LF>Driver 2: standstill, SG <Warning: Maximal number of bytes per line exceeded! Check the end-of-line settings or increase the limit in the advanced terminal settings.>
            M587 with no pparameters returns
            Error: M587: Failed to retrieve network list<LF>
            ayudtee 1 Reply Last reply Reply Quote 0
            • ayudtee
              ayudtee @IanWalton last edited by ayudtee
              @ianwalton If your Setnetwork macro still exists in its default location, execute it in the console by sending "M98 P/macros/SetNetwork". Then send a M587 and check that your network is listed, and then send a M552 S1. Every once in a while my duet wifi does this and this is the procedure that works for me. I'm tempted to get a paneldue to make things easier than fetching the usb cable, but the usb cable has always worked so far when the network stalls. Good luck.
              IanWalton 2 Replies Last reply Reply Quote 0
                Please change the line end sequence in YAT (if that is what you are using) to LF and run M122 again.
                I suspect that you have an incompatible version of DuetWiFiServer.bin installed, and/or that you are not enabling wifi in config.g.
                • IanWalton
                  IanWalton @ayudtee last edited by
                  @ayudtee it does exist there, i updated it in an external sd reader, reinstalled it in the duet board and tried running it.
                  came back
                  Warning: Macro file /macros/SetNetwork not found.
                  • IanWalton
                    IanWalton @dc42 last edited by
                    SENDING:M122
                    Dynamic ram used: 100448
                    Recycled dynamic ram: 2184
                    Last reset 00:00:21 ago, cause: software
                    Last software reset time unknown, reason: User, spinning module GCodes, available RAM 7864 bytes (slot 3)
                    Error status: 0
                    MCU temperature: min 31.6, current 31.9, max 32.0
                    Supply voltage: min 12.2, current 12.3, max 12.3, under voltage events: 0, over voltage events: 0
                    Slowest main loop (seconds): 0.000259; fastest: 0.000049
                    MaxReps: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
                    Scheduled moves: 0, completed moves: 0
                    Bed compensation in use: none
                    Segments left: 0
                    Movement lock held by null
                    http is idle in state(s) 0
                    telnet is idle in state(s) 0
                    file is idle in state(s) 0
                    serial is ready with "M122" in state(s) 0
                    aux is idle in state(s) 0
                    daemon is idle in state(s) 0
                    queue is idle in state(s) 0
                    Code queue is empty.
                    === Network ===
                    HTTP sessions: 0 of 8
                    • WiFi -
                      Network state is starting
                      WiFi module is disabled
                      === Expansion ===
                    network state is starting
                    wifi module is disabled
                    hmmm, ive got a spare sd card somewhere, going to try reformatting it and starting fresh
                    • IanWalton
                      @ayudtee
                      sigh, im a dumbass, macro wasnt correct name, but, i corrected it and got it to run
                      hasnt changed anything though 😞
                      • IanWalton
                        config file contents
                        ; Configuration file for Duet WiFi ver 1.
                        M555 P1 ; Set firmware to look like RepRapFirmare
                        M550 PCR10 ; Set machine name
                        M552 S1 ; Enable network
                        M587 S"PLUSNET-Q6QW" P"xxxxxxxx" ; access point
                        M350 X16 Y16 Z16 E16 I1 ; Configure microstepping
                        M92 X80 Y80 Z4000 E420 ; Set steps per mm
                        M566 X900 Y900 Z12 E120 ; Set maximum speed changes
                        M203 X6000 Y6000 Z180 E1200 ; Set maximum speeds
                        M201 X500 Y20 Z250 E250 ; Set accelerations
                        M906 X800 Y800 Z800 E800 I30 ; Set motor currents (mA)
                        M84 S30 ; Set idle timeout
                        M208 X300 Y300 Z400 S0 ; Set axis maxima
                        M574 Y2 S1 ; Set active high endstops
                        M574 X1 Z1 S2 ; Set endstops controlled by probe
                        M558 P1 H5 F120 T6000 ; Set Z probe type to unmodulated and the dive height + speeds
                        G31 P500 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
                        M557 X45:275 Y45:275 S20 ; Define mesh grid
                        M563 P0 D0 H1 ; Define tool 0
                        ; Automatic power saving
                        M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
                        ;M501 ; Load saved parameters from non-volatile memory
                          @ianwalton said in duet wifi connection issues:
                          WiFi -
                          That bit suggests either an incomplete wifi firmware installation or an incompatible wifi firmware version. I suggest you do this:
                          • download DuetWiFiServer.bin again from https://github.com/dc42/RepRapFirmware/releases/tag/1.21
                          • use a PC to copy it into /sys on the SD card
                          • safely remove/eject the SD card from the PC
                          • put it back in the Duet, then start the Duet
                          • send M997 S1 from YAT to install it, and check that it reports success
                          • send M552 S0. It should respond "WiFi module is idle" after a few seconds.
                          • then you can try sending the M587 command again from YAT to set your access point SSID and password.
                          • IanWalton
                            did as you asked
                            M997 reported successful upload.
                            M552 S0 does not respond
                              After sending M552 S0, please wait a few seconds, then run M122 and post the result here.
                              PS - also try sending M552 S-1 before the M552 S0.
                              • IanWalton
                                M552 S-1returns ''WiFi module stopped''
                                M552 S0 returns nothing
                                M122 returns
                                Used output buffers: 1 of 32 (9 max)
                                Stack ram used: 3576 current, 4720 maximum
                                Never used ram: 7568
                                Last reset 01:20:22 ago, cause: reset button or watchdog
                                Error status: 0
                                MCU temperature: min 31.9, current 32.0, max 32.5
                                Slowest main loop (seconds): 0.099909; fastest: 0.000050
                                Segments left: 0
                                === Network ===
                                • WiFi -
                                  === Expansion ===
                                • IanWalton
                                  i did a M122 after the S-1 and the only difference i could see was ''network state is disabled''
                                    I am beginning to suspect that your WiFi module is faulty because the "Network state is starting" state should not persist. But first, another test please. Do you have a M552 command in config.g? If so:
                                    • remove it or comment it out
                                    • restart the Duet, wait a few seconds, run M122 and post the result here
                                    • send M552 S0, wait a few seconds, run M122 and post the result here.
                                    • IanWalton
                                      IanWalton last edited by IanWalton
                                      you can see whats in my config.g file further up.
                                      i commented out all the network stuff, rebooted and the wifi led didnt flash
                                      first m122
                                      Stack ram used: 3576 current, 4504 maximum
                                      Never used ram: 7784
                                      Last reset 00:00:41 ago, cause: software
                                      Last software reset time unknown, reason: User, spinning module GCodes, available RAM 7784 bytes (slot 0)
                                      Error status: 0
                                      MCU temperature: min 31.3, current 31.4, max 31.8
                                      Slowest main loop (seconds): 0.000153; fastest: 0.000049
                                      Segments left: 0
                                      === Network ===
                                      • WiFi -
                                        Network state is disabled
                                        Failed messages: pending 2779096485, notready 2779096485, noresp 2779096485
                                        === Expansion ===
                                      sent m552 s0, no reply on yat
                                      M122 returns
                                      Stack ram used: 3576 current, 4664 maximum
                                      Never used ram: 7624
                                      Last reset 00:02:15 ago, cause: software
                                      Error status: 0
                                      MCU temperature: min 31.1, current 31.9, max 31.9
                                      Slowest main loop (seconds): 0.099142; fastest: 0.000049
                                      Segments left: 0
                                      === Network ===
                                      • WiFi -
                                        === Expansion ===
