    Controlling 3D printer via auxiliary UART
    • David
      David last edited by
      Hi, I have some questions about controlling 3D printer via auxiliary UART, specifically about Chamber and Busy state.
      Right now, printer has this firmware:
      Firmware Name: RepRapFirmware for Duet WiFi
      Firmware Electronics: Duet WiFi 1.0
      Firmware Version: 1.20 (2017-12-23)
      1. Is there a way how to get Chamber status and temperature from M408 S0, just like bed or standard heater? I don’t know if there is config issue or there is no way how to get that from M408 S0 G-Code. The config looks all right, because the web interface recognizes the chamber the right way, just like the bed. M408 S0 doesn’t return the chamber temperature even in “G-Code Console” in web interface.
      2. I found weird behavior with responding when the printer is in Busy state. The app is asking every second with “M408 S0 R”. The weird part is that sometimes the printer is returning that its in Busy state, but sometimes it’s not even returning anything, just not responding (but in web interface I can see, that the printer is in Busy state). Are there some differences in Busy states?
      Thank you for answer and sorry if I missed some topics in this forum, I tried to search, but did not find anything about this.
      David
      • T3P3Tony
        have you tried using response type 2 M408 S2 - that is similar to what DWC uses as far as I know and should have more information in it.
        • David
          Yes, I know about M408 S2. I was just wondering if there is a way to get that from S0. Because bed is working on that, so I was thinking that might be similar.
            dc42 administrators @David last edited by
            AFAIR the M408 S0 response includes the temperatures of all heaters that are used as bed or chamber heaters or used by a tool. But it doesn't tell you which ones (if any) are being used as chamber heaters.
            • David
              Ok, I don't know how to reproduce that workflow.
              I have this configuration:
              M301 H0 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
              M305 P0 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 0
              M301 H0 S0.90 ; Set heater 0 PWM limit to 90%
              M305 P1 T100000 B4388 C0 R4700 ; Set thermistor + ADC parameters for heater 1
              M301 H1 S0.90 ; Set heater 1 PWM limit to 90%
              M141 H2 ; heater 2 is the chamber heater
              M301 H2 B1 ; use bang-bang control for the chamber heater
              M305 P2 T100000 B4388 C0 R4700 ; Set thermistor + ADC parameters for heater 2
              M143 H2 S80 ; Set temperature limit for heater 2 to 80C
              When I send “M408 S2”, I get this response (which I think is ok):
              {"status":"I","coords":{"axesHomed":[0,0,0],"extr":[0.0],"xyz":[0.000,0.000,317.000]},"currentTool":0,"params":{"atxPower":0,"fanPercent":[100.00,0.00,100.00,0.00,0.00,0.00,0.00,0.00,0.00],"speedFactor":100.00,"extrFactors":[100.00],"babystep":0.000},"sensors":{"probeValue":0,"fanRPM":0},"temps":{"bed":{"current":23.1,"active":0.0,"state":0,"heater":0},"chamber":{"current":22.8,"active":0.0,"state":0,"heater":2},"current":[23.1,23.8,22.8,2000.0,2000.0,2000.0,2000.0,2000.0],"state":[0,2,0,0,0,0,0,0],"heads":{"current":[23.8],"active":[0.0],"standby":[0.0],"state":[2]},"tools":{"active":[[0.0]],"standby":[[0.0]]},"extra":[{"name":"MCU","temp":37.6}]},"time":2132.0}
              If I send “M408 S0”, I get this response:
              {"status":"I","heaters":[23.0,23.8],"active":[0.0,0.0],"standby":[0.0,0.0],"hstat":[0,2],"pos":[0.000,0.000,317.000],"sfactor":100.00,"efactor":[100.00],"babystep":0.000,"tool":0,"probe":"0","fanPercent":[100.00,0.00,100.00,0.00,0.00,0.00,0.00,0.00,0.00],"fanRPM":0,"homed":[0,0,0],"msgBox.mode":-1}
              As you can see, that S0 return only two temperatures. Does anybody can help me with that? I don’t know if there is bug in M408 or in the config.
                Looks like M408 S0 doesn't return the chamber heater temperature, just the bed and tool heater temperatures. I suggest you use M408 S2.
                • David
                  Ok, thank you
