Duet wifi fan and heater not working
Hi I been converting my tevo little monster to a duet wifi with smart effector. I got it configured (I think) and was able to run a g32 successfully.
I used the reprap config tool to set up.my .g files.
I tried using the web controll and sending gcode through the console to turn on the fan and heaters. I get 0v at the terminal blocks for the bed and hot end. The berdair pump won't turn on either. The pump will blip twice during startup though so I know that works.Any ideas?
Also I think I elected bang-bang for the heating style? Not entirely sure about that though.
have you configured a tool that encompases the bed\heater\fans ??.
Forgot to add that your tool should look something like this:
M563 P0 D0 H1 F0 F1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C -
Here is my heater, fan and tool code
Heaters
M140 H1 ; Remap heated bed to heater 1
M301 H1 P-1 ; Set heater 1 to bang-bang mode
M305 P2 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 2
M143 H2 S280 ; Set temperature limit for heater 2 to 280C; Fans
M106 P1 S1 I0 F500 H2 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P2 S1 I0 F500 H2 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 D0 H2 ; Define tool 0
In case the pic dissent show up this should link to it
https://photos.app.goo.gl/Tn0Mljiy72QYZWqo1 -
If it helps, this is my config, but I don't do any re-maping:
; Bed
M143 H0 S150 ; Set Max temperature limit for heater 0 (Bed) to 150C
M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
M305 P0 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 0 (Bed); Hot End
M143 H1 S290 ; Set Max temperature limit for heater 1 (HotEnd 1) to 290C
M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1 (Hotend 1)
M307 H1 A228.5 C122.8 D7.4 S1 B0 ; Set PID for heater 1 (Hotend 1) -
and for the fans:
M106 P0 I0 F10 H-1 ; Set fan 0 (Part Cooling fan) value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S1 T50 H1 ; Set Fan 1 (Extruder 0 fan) comes on at 50 degrees
M106 P2 S0.5 T55 H100:101:102 ; Set fan 2 (Duet Board) to come on half power if any driver chip reaches 55 degrees -
You need to select the tool by sending T0 before you can heat it. But Fan 0 as you have configured it should start running at 30% PWM as soon as you power up the Duet. Also the illumination LEDs should come on at 30% brightness.
Your M301 command for the bed is obsolete and may be the reason the bwe heater doesn't work. You should delete it, restart and run bed heater tuning to generate a M307 command for it.
ok i got this stepper for my extruder and the data sheet says its pin out is
Black(A+), Green(A-), Red(B+), Blue(B-)
so im wondering is a1 a+ and a2 A-? and same for b? -
never mind we figured it out. i got the heaters and pump working now thank you all
