    Fan0 problem - not working anymore
    • Scachiundefined
      Scachi
      it looks like I managed to damage my fan0 output.
      I had a faulty contact/wire as the fan sometimes stopped working for a short time during print but the fan0 is configured to thermostatic mode so it shouldn't do that. After replacing the wires and the fan I can't get it to work anymore, my fault for sure.
      It still reads 13V but I can't get the fan to work anymore with full power.
      The fan only works when I give it a light starting spin, it rotates very slowly without stopping then.
      I have tried another fan on this output without success. The fan does work fine on fan1 but I have all of them in use so I can't use that as a long term solution.
      I can see no damage on TR5 - Will replacing the TR5 fix my issue ?
        dc42 administrators @Scachi
        @scachi said in Fan0 problem - not working anymore:
        Yes, very probably.
        • Scachiundefined
          Scachi
          Replacing the TR5 did fix my issue.
          I'll spend more attention now to not shorten it again as I don't want to solder something tiny like that again ☺
