Not able to PWM for berd air pump
  • Hi all,
    I recently got curious about berd air cooling, I got a 24V pump and followed the instructions regarding flyback diode and current limiting thermistor. My other post in the thread shows the setup pictures:
    https://forum.duet3d.com/topic/4477/24v-pump-can-i-connect-direct/8
    When I connected the pump to FAN0 or FAN2 (my original dual fan set up), the pump motor did not run. I connected directly to 24V power supply and it works. I connected my fans back to check whether I blew the MOSFET or not, but thankfully I was able to run the fans with no problem, so I did not blow the MOSFET.
    I connected the pump to always on Fan port in duet and the pump works fine. I suspect that I might have the wrong PWM frequency, so looking at berd air configuration post, I set the F parameter in M106 to 25kHz and it did not work. I tried 500, 100 and the original 250 still no luck.
    I am not an electrical engineer but I think it has something to do with PWM frequency. I might be wrong. Can someone please help me to sort this issue. My duet version is 1.01 and I am running firmware 1.21
    Cheers,
    Vasan
    When you connected the pump to the always-on fan connector and it ran, were the flyback diode and thermistor still in the circuit? If so then they can't be causing the problem.
  • @dc42 I had fly back diode and thermistor connected all the time. The pump does not run at all when I connect to Pwm fan ports but ran fine with always on fan port. I am not sure what is the problem with Pwm control of this pump. Any suggestions would be helpful.
    Cheers,
    Vasan
    @sm3d said in Not able to PWM for berd air pump:
    Cheers,
    Vasan
    Does it work when you specify full PWM, i.e. S1 or S255 in the M106 command?
  • @dc42 I was travelling and could not reply you faster. Here is the configuration for fan
    M106 P0 S255 I0 F25000 H-1
    I tried both S1.0 and S255 but nothing happened with PWM fans. As I mentioned, the pump works fine with always on fan ports.
    What is the difference between S factor mentioned in M106 and slider used in Duet web control? Do they perform the same function.
    While I am typing this my config.g got deleted automatically and I see config.g.bak. Any idea how to recover my config.g file
  • Took the SD card out, renamed the config.g.bak to config.g, the duet is back online but still I have this problem with the pump
    Cheers,
    Vasan
    Does it work if you short out the thermistor? I don't recommend running it like that for long, but I recall that someone else found that the thermistor stopped the motor from starting - indicating that a physically smaller thermistor is needed.
  • @dc42 I connected the positive from the pump directly without the resistor. I also tried by touching both the legs of transistor together effectively shorting them(hope I am correct) still no luck.
    That's odd, because with the FET shorted its Fan connector is in parallel with the always-on connectors, and you said that the pump works on those (even with the thermistor).
  • Yes I agree with you that its odd. I don't know what to do. Thanks @dc42 for your suggestions so far.
    Cheers,
    Vasan
    You could use a multimeter to check for low resistance between the VFAN pins of the always-on and controlled fan connectors. Also to check for low resistance between the mosfet source pin and the ground pin of the always-on fan connector.
    Then connect the pump/thermistor combo to a controlled fan output, set that fan to full PWM and not thermostatic control, switch your multimeter to Volts and measure between the VIN ground terminal and each of:
    • FAN- output on the controlled fan connector
    • VFAN output on the controlled fan connector
    • Mosfet source pin
    Take great care when measuring these voltages! Many users have shorted the fan output pins together when trying to take similar measurements, resulting in a blown mosfet. So plan how you are going to do it with no risk of shorting anything, and do a dummy run with power off first.
  • Hi David @dc42 ,
    Thanks for your help and suggestions! My knowledge in electrical engineering is very limited so pardon my silly questions. I use duet v1.01, may I know where is the MOSFET source pin? I am trying to write the procedure in steps based on my understanding.
    Step 1:
    Check the resistance between V_FAN pin of FAN_0 and V_FAN pin of Always on Fan
    Step 2:
    Check the resistance between MOSFET source pin and ground pin of Always on Fan - Where is the MOSFET source pin in Duet wiring diagram
    For Step 1 and 2 what are the typical resistance values?
    Step3:
    Connect the pump with thermistor to one of the PWM control fan pins then measure the voltage between:
    (i) Negative pin of the PWM fan connector and VIN Ground terminal (-ve pin of the power input)
    (ii) Positive pin of the PWM fan connector and VIN Ground terminal (-ve pin of the power input)
    (iii) Mosfet source pin and VIN Ground terminal (-ve pin of the power input)
    In the duet wiring diagram, if you can indicate where is the MOSFET source pin, it will be helpful.
    If it involves a high probability of blowing up a MOSFET, I rather prefer not to do it because I do not have the skills to solder them back.
    Thanks again for your help!
    Cheers,
    Vasan
  • Same issue there, thermistor doesn't close the circuit.
    I've removed it for the moment, hope not for too long 🙂
    @dc42 mentionned in a another post that it may be due to the motor not drawing enough current to heat up the thermistor (Posting this to merge backlog discussion in this dedicated topic)
  • @dc42 @Hergonoway The problem is solved. I reduced the frequency F parameter to 10 to see what happens and voila, PWM worked. Then I raised it to 100, still worked. I am yet to check higher frequencies (will do in the evening).
    Previously, I used F25000, F500 and F100 but it did not work. Now out of the blue it works. I haven't changed anything in my setup.
    Cheers,
    Vasan
Locked
