    Disable extruder endstop
    • AdrAs
      AdrAs last edited by
      I've got a delta printer, nothing connected to the extruder endstop. But in the machine properties the extruder endstop is listed as hit, which means I can't extrude anything.
      How can I invert or disable the extruder endstop?
      • AdrAs
        Ok, I just created a plug to connect the two outside pins of the Extruder endstop together. That way it's inverted...
        • T3P3Tony
          disable filament out sensing on the extruder and that should clear up the issue:
          https://duet3d.dozuki.com/Wiki/Gcode#Section_M591_Configure_filament_sensing
          • AdrAs
            Thank you very much!
              By default, extruder endstops don't do anything. The usual reasons for not being able to extrude are:
              • no tool selected (so it doesn't know which extruder drive to use);
              • tool not heated and cold extrusion not enabled.
              In either case there should be an error message on the GCode Console page od Duet web Control.
              HTH David
              • AdrAs
                Yeah, seems like it. Initially I was just confused of the endstop being listet as "hit", so I thought I could never print that way. Therefore I never even tried to extrude or print anything. I thought the "safest" way to get a print going was just to create a "jumper" for that endstop.
                I'm thinking about disabling the cold extrusion prevention, but I'm not sure if I want to do that, because it's kind of a safety feature. Although it probably doesn't cause much harm to cold extrude. I don't have a geared extruder so it will just keep slipping and losing steps until I can shut off the printer noticing my fault 🙂
                • T3P3Tony
                  T3P3Tony administrators @AdrAs last edited by
                  @adras I would leave cold extrusion prevention turned on - that way you get an error message if you try to extruder with the hotend cold.
