    M558 - What is 'Dive Height'?
    • SnowCrash
      SnowCrash last edited by
      The gcode wiki specifies a 'Dive Height' parameter (Hnnn), but I couldn't find an explanation about what this parameter does or how it works.
      Could anyone please clarify?
      Many thanks,
      SnowCrash
      • T3P3Tony
        The Dive height is the height above the (assumed) height of the bed that a probing move will start:
        The H parameter defines the Z probe dive height, which is the height above the trigger height from which probing starts. The default is 3mm or 5mm depending on firmware version. You may wish to increase it during initial calibration.
        https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_Z_probe_section
        I have updated the gcode page as well to explain that.
        www.duet3d.com
        SnowCrash 1 Reply Last reply Reply Quote 0
          It's also the maximum depth below the assumed position of the bed that probing will go to try to find the bed.
          • SnowCrash
            SnowCrash @T3P3Tony last edited by
            @t3p3tony said in M558 - What is 'Dive Height'?:
            @dc42 said in M558 - What is 'Dive Height'?:
            Thanks for the clarifications, @T3P3Tony & @dc42!
