    New board faults
    1.5k
    • micktolundefined
      micktol
      I have just received a duet ethernet board, before doing anything I checked the soldering etc.
      There are 3 faults!
      Capacitor c111 is soldered between one of its connections and one of the resistor next to it.
      Capacitor c104 is only soldered on 1 side as it is misplaced.
      There is a large amount of white paste around the area of c53 c60.
      Is this a problem?
      • T3P3Tonyundefined
        T3P3Tony administrators
        @micktol That is not great 😕
        I am very sorry you have received a board in this state. Please can you contact your supplier (or me by email if you bought it directly from us) and arrange a warranty replacement. you can reference this thread.
        www.duet3d.com
        • wilrikerundefined
          wilriker
          @T3P3Tony It never occurred to me to doubt the quality of the board in the first place.
          Now I have looked at it and I found a couple of solder pads where no components are actually soldered to but I have no idea where to check whether this is intentionally or a fault (certainly I had no issues with my board so far, so at least I guess these are missing by definition).
          Instead of spamming this thread could you please tell me where I can find if and what components are supposed to be missing on a Duet Wifi that have declaration on silk screen and solder pads prepared?
          Manuel
          My Tool Collection
          • T3P3Tonyundefined
            T3P3Tony administrators @wilriker
            @wilriker There are a number of DNP 0603 resistors, they are annotated on the schematic:
            https://github.com/T3P3/Duet/blob/master/Duet2/Duet2v1.03/Duet2_Schematic_v1.03.pdf
            www.duet3d.com
            • wilrikerundefined
              wilriker @T3P3Tony
              @t3p3tony Thanks! I will take my printer apart tomorrow (this is a planned activity 😉 ) and as part of that I will closely examine the board and compare it to the documentation regarding DNP. I do not expect anything unusual as my board worked flawlessly as long as I have it (about a month) but this thread now got me started. 😁
              Manuel
              My Tool Collection
              • T3P3Tonyundefined
                @wilriker a quick summary to save you time:
                R73, R74,R75,R76 close to the SD card, along with the JTAG port and associated resistors, R35,R49,R52
                these can all be seen in the image above
                R82 and C83 around the ESP
                and C95 next to the 3.3V LDO:
                HTH
                www.duet3d.com
                • wilrikerundefined
                  wilriker @T3P3Tony
                  @t3p3tony Thanks, that made things a lot easier. 🙂 I can at least confirm now that nothing else is missing.
                  Only thing I found is that the large extension header and the VIN terminal block both are not sitting 100% flat on the PCB. This has no functional issues AFAICT but is something the assembling should be advised to look after.
                  I will attach photos in a moment.
                  All pins in both cases are soldered correctly, so again, I see no functional issues here.
                  Manuel
                  My Tool Collection
                  • micktolundefined
                    micktol
                    I have received the replacement board and c111 is misplaced as before, quality control?
                    What NOW?
                    • T3P3Tonyundefined
                      T3P3Tony administrators @micktol
                      @micktol I have replied to your new thread.
                      www.duet3d.com
