    Printing without a heater (syringe clay printer)
    1061
    • tom_lauerman
      tom_lauerman last edited by
      Re: No heater printing
      Hello, I have built a clay printer which does not require any heating. I am new to RepRap Firmware, having previously used Repetier. I like RepRap firmware so much better already. I have been able to print without heaters by sending the M301 P1 command to enable cold printing. However, I would prefer to set up the machine as a "permanent" cold printer. I listed the number of heaters on my tool as 0, but i still get the temp warning until I send the M301 command. One aspect I liked about Repetier was the option in their firmware configurator to set the temperature sensor to "fake temperature sensor, always returning 25c". Would it be possible when configuring a syringe based paste printer to setup the firmware to omit all the temperature related settings?
      tom_lauerman deckingman 2 Replies Last reply Reply Quote 0
      • tom_lauerman
        tom_lauerman @tom_lauerman last edited by
        @tom_lauerman I'm using a Duet Wifi and i have the 1.21 Firmware and interface.
        • deckingman
          deckingman @tom_lauerman last edited by
          @tom_lauerman
          I'd have thought putting M301 P1 at the end your config.g ought to work.
            This should work already, we have at least one other user controlling a clay printer with a Duet. Which firmware version are you using? Please post the contents of your config.g file.
            One known bug is that the layer count displayed in Duet Web Control doesn't increment when there are no tool heaters. This is fixed in the 2.0RC6 firmware.
            tom_lauerman 1 Reply Last reply Reply Quote 1
            • tom_lauerman
              tom_lauerman @dc42 last edited by
              @dc42 Thanks for your reply! I'm running firmware version 1.21. Here are the contents of my config.g file:
              ; Configuration file for Duet WiFi (firmware version 1.17 to 1.19)
              ; generated by RepRapFirmware Configuration Tool on Fri Jun 01 2018 14:49:13 GMT-0400 (Eastern Daylight Time)
              M555 P1 ; Set firmware compatibility to look like RepRapFirmare
              M550 PBricoleur ; Set machine name
              M552 S1 ; Enable network
              M587 S"attwifi" P"" ; Configure access point. You can delete this line once connected
              M586 P0 S1 ; Enable HTTP
              M586 P1 S0 ; Disable FTP
              M586 P2 S0 ; Disable Telnet
              M569 P4 S1 ; Drive 4 goes forwards
              M350 X16 Y16 Z16 E16:16 I1 ; Configure microstepping with interpolation
              M92 X80 Y80 Z4000 E5000:370 ; Set steps per mm
              M566 X900 Y900 Z12 E120:120 ; Set maximum instantaneous speed changes (mm/min)
              M203 X6000 Y6000 Z180 E1200:1200 ; Set maximum speeds (mm/min)
              M201 X500 Y20 Z250 E250:250 ; Set accelerations (mm/s^2)
              M906 X800 Y800 Z800 E2000:800 I30 ; Set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              M208 X480 Y317 Z750 S0 ; Set axis maxima
              M574 X1 Y1 S1 ; Set active high endstops
              M558 P0 H5 F120 T6000 ; Disable Z probe but set dive height, probe speed and travel speed
              M557 X15:465 Y15:302 S20 ; Define mesh grid
              M140 H-1 ; Disable heated bed
              M106 P1 S1 I0 F500 H T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
              M106 P2 S1 I0 F500 H T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
              M563 P0 D0:1 H ; Define tool 0
              M568 P0 S1 ; Enable mixing for tool 0
              M567 P0 E0.5:0.5 ; Set mixing ratios for tool 0
                @tom_lauerman said in Printing without a heater (syringe clay printer):
                Remove the letter H from that command, because it is being treated as if it says H0.
                • tom_lauerman
                  Fantastic! That did the trick. The extrude and retract buttons are grayed out in the web control but they still extrude or retract when clicked on. I understand from previous posts that this has been addressed in the RC versions. Would you recommend switching from 1.21 to the latest release candidate? I'm the only user of this machine - its a one-off for research purposes, not something designed for production and sale.
                    I released firmware 2.0 yesterday, so I suggest you try that.
                    • tom_lauerman
                      @dc42 Wow! I'll do that right now, thanks!
