    duet wifi + 3dtouch: offset keeps going up at each probe
    • janko
      janko last edited by janko
      I have a weird problem here with my touch sensor: each probe keeps going up higher and higher in the offset. I am breaking my head over it, but can't figure out what is going on.
      First of: what i mean:
      Stopped at height 3.408 mm
      Stopped at height 3.948 mm
      Stopped at height 4.191 mm
      Stopped at height 4.503 mm
      Stopped at height 4.589 mm
      Stopped at height 4.738 mm
      Probing is done at x110 y 110 Z10 with G30 S-1 command
      Parts out of the config.g:
      ; BLTouch - Heaters
      M307 H7 A-1 C-1 D-1 ; Disable the 7th Heater to free up PWM channel 5 on the Duex board.
      M558 P9 X0 Y0 Z1 H5 F500 T2000 A1 R0.5
      G31 X24 Y-2 Z0 P10
      homez.g (don't think that G30 uses this? but still, bytes are free 😄 😞
      G91
      G1 Z10 S2 F200
      G30 ; Do a single probe to home our Z axis
      G90 ; Make sure we are in absolute mode
      G1 Z10 F6000 ; Rapidly move the Z axis to Z=10.
      bed.g:
      ; Probe the bed at 4 points
      G30 P0 X15 Y15 H0 Z-99999
      G30 P1 X15 Y195 H0 Z-99999
      G30 P2 X195 Y195 H0 Z-99999
      G30 P3 X195 Y15 H0 Z-99999 S
      The touchsensor is a 3dtouch (i know, not as accurate as a bltouch, but this is a bit weird what is going on 😉 ), wired on the probe-in port for the signal, with a resistor between ground and signal wire.
      If anyone has any idea: i would be thankful, I'm kinda stuck at the moment.
      • janko
        To make sure it's not a firmwarethingie: upgraded just to 2.0(RTOS)RC6 (2018-05-29b4)
        results now:
        17:50:13G30 S-1
        Stopped at height 4.403 mm
        17:50:09G0 Z10
        17:50:01G30 S-1
        Stopped at height 4.257 mm
        17:49:57G0 Z10
        17:49:47G30 S-1
        Stopped at height 4.202 mm
        17:49:43G0 Z10
        17:49:29G30 S-1
        Stopped at height 3.736 mm
        17:49:24G0 Z10
        17:48:52G30 S-1
        Stopped at height 3.542 mm
        17:48:47G0 Z10
        17:48:42G30 S-1
        Stopped at height 2.804 mm
        17:48:37G0 Z10
        17:48:23G30 S-1
        Stopped at height -0.107 mm
        17:48:11G28 Z
        • Scachi
          Scachi last edited by
          I had this problem with one BLTouch. It started to do so after I managed to drive the BLTouch hard into the bed (missed some wiring after modifying my printer), I think that damaged my probe.
          After replacing it with a new BLTouch the problem was gone, not sure if there was another problem that may have caused this as I was still modifying my printer when I ordered the new one and tested it after finishing it with the new BLtouch only - So I can't guarantee that a new probe will fix your problem.
          • janko
            18:53:47G30 S-1
            Stopped at height -0.762 mm
            18:53:43G0 Z5
            18:53:35G30 S-1
            Stopped at height -0.647 mm
            18:53:30G0 Z5
            18:53:26G30 S-1
            Stopped at height -0.641 mm
            18:53:23G0 Z5
            18:53:17G30 S-1
            Stopped at height -0.757 mm
            Results after putting the trigger value up to 70 in stead of the 10 I started with. I followed the guide to setup the 3dtouch (bltouch guide actually) which stated that the trigger value had to be low, since the pulse of the sensor is very short. Seems it however has a negative effect on the output when you go low/very low.
            • Scachi
              I am using 25 as the trigger value.
              janko 1 Reply Last reply Reply Quote 0
              • janko
                janko @Scachi last edited by janko
                @scachi let me test that next 😄
                I now tried without the resistor between ground / signal wire (since duet 'bragged' about how idiotproof the board is, i felt lucky 😉 😞
                results now:
                19:18:03G30 S-1
                Stopped at height 0.000 mm
                19:17:56G0 Z5
                19:17:40G30 S-1
                Stopped at height 0.065 mm
                19:17:32G0 Z5
                19:17:24G30 S-1
                Stopped at height -0.039 mm
                19:17:19G0 Z5
                19:17:11G30 S-1
                Stopped at height 0.005 mm
                19:17:04G0 Z5
                19:17:00G30 S-1
                Stopped at height -0.013 mm
                This seems to be somewhat normal
                  What happens if you reduce the probing speed (F parameter in the M558 command)?
                  The probing move is terminated abruptly when the probe triggers, and if the probing speed is too high then it can overshoot.
