Hotend calibration
I'm looking to calibrate my hot and and doing properly. Would the following list be the correct procedure to calibrate it? Advice info and tips are welcome. Typical values for a Bondtech BMG directly mounted to a E3dv6 would be appreciated as well.
- PID tuning of the hotend.
- Temperature (using temptower to find the lowest working temp)
- Pressure advance (first minimize stringing here using two separate towers)
- Firmware retraction (eliminate the rest of the stringing using the same test as 2.)
KISSlicer will be used for the slicing.
@nxt-1 Don't forget E-steps calibration and PID tuning.
https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
@Phaedrux For E-steps I use the manufacturers recommend 415/mm. I'll add PID tuning to the list.
