Connect mechnical end stop switch to x and y axis
how can i connect it to the x and y axis
and what is the wiring
i am using duet 8.5
https://www.google.com.eg/url?sa=i&rct=j&q=&esrc=s&source=images&cd=&cad=rja&uact=8&ved=0ahUKEwj39dH7r-LQAhXDtxoKHTyWBlQQjRwIBw&url=https%3A%2F%2Freprapchampion.com%2Fproducts%2Flot-3-pcs-mechanical-endstop-switch-reprap-3d-printer-prusa-mendel-ramps-1-4-cnc&psig=AFQjCNFtYpywqOwe9hefxHPH7tlgdeTvQg&ust=1481210147087567
If it's like the ones I have. http://www.reprap.org/wiki/Mechanical_Endstop
Pin 1 VCC (+5vdc) led won't be as bright on 3.3vdc
Pin 2 Ground
Pin 3 Ground
Pin 4 Signalhttp://reprap.org/wiki/Duet_Wiring#Main_wiring
Connections to endstop connection on the Duet085:
Pin 2 or 3 to Ground
Pin 1 to center connector pin
Pin 4 to Signal
See also this wiki page https://duet3d.com/wiki/Connecting_endstop_switches#Makerbot_Mechanical_Endstop_v1.2.
